Show your new tool arrivals
Outahere
Idaho
Bought a 3M series-6500QL respirator at Amazon for $24. It is designed to fit well behind a face shield. It was in an open, very wrinkled 3M plastic bag, but I don't see any signs of the respirator being used. A few years ago Amazon sent me a dirty, used G-Shock wrist watch.
I also spent $6 on a pair of filters , for use with sawdust, silica, mold, etc. May cause cancer in California, says the warning label. :headscrat
CHI_Tool&Die
Chicago, IL
Finally received my Williams 1/4 flex head ratchet. It was on backorder for about six weeks. It’s a lot longer than I thought. Pretty smooth for 36 teeth. It completes my cheap ratchet set (I have all three drives sizes of the Williams flex head ratchets) that lives in my 5 drawer cart in the garage. So far my Williams ratchets have held up well. They aren’t my favorites but for the price I really can’t complain. I probably wouldn’t have bothered with them but I really wanted something for the garage so I didn’t have to keep dragging my good ratchets out of the house all the time.
Also received three Proto universal joints. I don’t really use these much and I figured I’d rather have these than universal sockets since these were way, way less expensive. These came from Zoro and I got a few 3/8 drive SAE sockets to fill out my Proto set.
Lastly, I was kicking my own *** for not purchasing the Hazet Smartcase set when it was on super sale during KC Tool’s Black Friday sale. It came up as tool of the day and I jumped on it. Yes, I know I spent more than I needed to but this set is really sweet. My only beef is that just like my Wera set, the longer bits don’t fit snug into the bit driver. Not the end of the world, but it’s just so odd. I mean the small bits fit great so I don’t understand why the longer ones have so much play.
zmotorsports
Northern Utah
Picked up a 'cheap' bjp1
You're going to love that ball joint press. Best one I've used and haven't touched my OTC since I bought this one about 5 years ago.
Mac scrapers on sale from last month. New Matco sealed head 1/4" dr ratchet. What's awesome is the lever is 360*.
You will really like that 1/4" drive ratchet. I have the much older MAC version that doesn't have the swivel lever but what I really like about this ratchet is that the fwd/rev switch is located further down from the center of the arbor. It never failed I would back out a fastener against something and the direction would change unexpectantly. Not so with this ratchet.
Al Borland
Don't use those for silica or mold, get P100 filters.
Also, CLEAN the respirator before use. (In case the Amazon workers wore it as an "athletic supporter")
boom_bap
Idaho
P100 2097 are the standard for welding. I think 2197 as well those are newer, lighter, and more expensive though.
Chance
New England
I use P100's for everything except nuisance dust, now. Now that we know how bad PM 2.5 is for lung health, they seem well worth the price. I should probably use them for nuisance dust too, but I'm just more likely to pop a N95 on my face for 2 minutes since I always have one in my pocket.
f121
UK
What is a p100, n95 and pm2.5?
Chance
New England
PM 2.5 means particulate matter 2.5 micron. Its the size of dust/dirt/contaminant particle most difficult for filters to catch. Bigger is caught by the "mesh" of the fibers and smaller is caught by the electrostatics which make the tiny particles veer and slam into the fibers and stick. The 2.5 micron size is hardest to catch by the "mesh", but massive enough to not veer toward the individual fibers as fast. (You may not realize it, but the fibers of these masks have a small charge captured inside them. They are really amazing technology, they are not just a synthetic cloth. They actually get zapped into having a charge stuck inside the fibers that attracts particles because small particles in the air statisticly have a slight charge imbalance.)
Unfortunately, it turns out that particles at the 2.5 micron size are small enough to get trapped in the lung tissue, but still large enough for your body to react to them. They more exposure you have, the higher your chances of having lung disease, even though you don't smoke, don't work in a coal mine, play with asbestos, etc. So doing what you can to cut down on your exposure should benefit you later in life.
P95 is a filter that stops 95% of the 2.5 micron particles.
P100 is a filter that stops 99.98 % (I think) of the 2.5 micron particles.
N95 are the dust and medical masks (typically white or green) which are made of 3 layers of material similar to P95 filter media. N95 is the "real thing" tested more stringently, but were diverted to medical use only during the pandemic. KN95 are the chinese-made equivalents, but which aren't tested to the same degree. And now are in many colors, not just white.
Disclaimer: You will get more precise / correct definitions from Wikipedia. This is just as best as I recollect in the moment. Its roughly correct but probably has errors.
f121
UK
PM 2.5 means particulate matter 2.5 micron. Its the size of dust/dirt/contaminant particle most difficult for a filters to catch. Bigger is caught by the "mesh" of the fibers and smaller is caught by the electrostatics which make the tiny particles veer and slam into the fibers and stick. The 2.5 micron size is hardest to catch by the "mesh", but massive enough to not veer toward the individual fibers as fast. (You may not realize it, but the fibers of these masks have a small charge captured inside them. They are really amazing technology, they are not just a synthetic cloth. They actually get zapped into having a charge stuck inside the fibers that attracts particles because small particles in the air statisticly have a slight charge imbalance.)
That's very useful, thanks.
WWheeler
Middleofnowhere USA
I have two of those Williams M-52EHFA ratchets, one as it comes and the other with a Snap-on RKRFC936 kit swapped into it to make it 3/8" ratchet in a 1/4" body. I use both often.
CHI_Tool&Die
Chicago, IL
I hope you don't mind me asking, but are your heads kinda loose? I noticed that both my 1/2" and 1/4" are kinda floppy so I took them apart but I can't seem to get the flop out. I don't mind them loose, but it ***** putting a socket on and having it droop 90 degrees.
Fedwrench
Valley of the sun
Those are such an underrated ratchet. They were ahead of their time too. Thin head, high tooth count, hard handle but comfort grip shape, low profile quick release, etc.
In 1/4 and 3/8 drive, absolutely!!! 1/2 drive was too short and heavy. The paint brush shaped handle is very comfortable. Probably the first of the floating pawl to market that are everywhere now. :beer:
WWheeler
Middleofnowhere USA
None of mine ar what I'd call loose.
Right or wrong I just tighten or loosen the torx bolt holding the flex head on until it is as tight or floppy as I like. Doing that with my Snap-on and Williams ratchets that have that bolt instead of just a pin has always worked for me for quite a bit of use before it ever needs adjusting again, if ever. I've never even thought about taking any of the flex joints apart.
Etchase
Hawaii
I’m not suppose to buy any more vise grips. I’m not suppose to buy any more adjustable wrenches. Stanley, made in China, with really good plating, and pretty tight key way, but it doesn’t need to be with the locking action. Over all, it’s a handy tool if you don’t have a wrench. I don’t see any disadvantages compared to a traditional adjustable. This takes care of the loose fit problem completely. And the release is in the correct direction.
jeffmoss26
Cleveland, Ohio
70chevellegsp
Good info on the respirators, thanks! Just ordered a new mask and cartridges this morning. Also received a Makita 1/2” cordless impact, 2 - 5ah batteries and charger. Took it to the farm today to remove a broken disk and it took the 1 5/16” nut off no problem in no time. Took a 2’ breaker with a 4’ pipe last time and about an hour. This time was easy👍
Etchase
Hawaii
Me too. Permanent finger damage and dropped parts and tools working with those Pertersen’s. Craftsman’s were in the correct direction at the time. I preferred those circle I “vice grips”. Nostalgia!
Komet
WA
I liked my Eklind bright torx keys so much I got the matching Metric and Inch hex sets to replace my partially complete Craftsman Inch and Kobalt Metric folding hex set. Those two will now live in the emergency kit.
Chance
New England
1. Which set is that (I tried to look it up and didn't spot the non-ball end bright ones. And 2. what do you like about them?
Komet
WA
It's the Eklind 11122. I like the tight fit of the torx keys in my fasteners, they're superior to my Pittsburgh gear. The bright finish doesn't rust like black oxide when you get sweat all over them and forget to lube them after. These seem resistant to everything and I can treat them like a chrome wrench with a simple wipedown. Also I think the price is good for made in USA gear.
