Show your new tool arrivals
shoggoth80
Seattle
Chisels and punches from the Freight 🤣 I've got a ball joint job coming up. My commuter is GM... And the joints are OEM... Riveted in place. So if I can't grind the heads off, I'll hack them off. Lol.
Slight gamble on these. There's not a ton of slim wrench options out there I know of. This was largely satisfying curiosity... But there's situations where these could be handy. Just over $20 after tax. I'll take that gamble.
Squankum
Southeast
Hmmm... I've done that job on a early Durango. I followed the Mopar protocol:
1? Cut an X pattern into the rivet head with a cutoff wheel
2? Drill down into the center some with a 1/2" bit? (I forget the size and the order of these two steps.
3. Chisel time! And I used an air chisel and am very glad I did. Fast and fun. Buzzy McWimp $50 Ingersoll-Rand type, not the beastly kind of air hammer.
Tip: put a wad of towels or cardboard or whatever to prevent the top of that rivet head ricocheting into the engine bay when it gives way.
freudianfloyd
Nowhere
Im late on posting these.
I haven't really picked up many tools lately. However, I did pick up some rather large pieces of equipment recently that I guess can be posted here.
First, a while back I started a thread about deciding between a skid steer or a backhoe. Since I had access to a skid steer and mini excavator that are next door, I decided a backhoe would be the best option for my farm.
Well I found exactly what I was looking for at the Columbus Cat dealer. 2011 John Deere 410 J TC with low hours.
So while not new, it is new to me. I love this thing and the boys love riding on it.
I have already put it to work. Started running leach lines for our septic and digging out the spring that was left in disrepair. The spring was so overgrown that you wouldn't even know it was there and so full of mud that it was only a puddle. This whole area is now full like a small pond.
Then I decided I needed a better more modern tractor. I had a 1968 Massey Ferguson 150 High Crop, a 1941 Farmall B and a Long 2460. I sold the Long and took advantage of the 0% interest through Kubota. Decided an MX6000 with hydrostatic transmission was the way to go.
All in all, it's been a good past few months.
It's a shame the weather has turned. It's too wet and cold out to play with these now.
RMERR
Northern CA
Added a small Nova wood lathe to the shop, with a custom stand I built. Posted a thread in fabrications if interested: https://www.garagejournal.com/forum/threads/nova-wood-lathe-makeover-with-custom-lift-stand.540327/
A Coast G20 penlight. It's small enough to hold in my mouth without chipping a tooth. No multi-mode nonsense, simple on-off. Nice sharp spot.
And just hours ago, a steal deal at a thrift store on a vintage telescoping Vemcolite drafting lamp . There's nine on Ebay right now, with shipping, from $125 to over $200. Fifteen bucks!
shoggoth80
Seattle
Air chisel would be the way to go, but no air power at home. 🤣 At work...100% would bust out air power.
Semi-hole mechanic
several thing I ordered from Temu just to try. Wrench holders for some of my DBE and DOEs in my new box and some shelves and paper towel holder. Also some cheap drawer labels because my wife helps me and I can tell her which drawer to look in, but I’m waiting to see if I like my organization first.
ching0n
picked from marketplace for 25 bones. Reads 5A w/no load and 8A w/load. Same "hercules" that goes for 200$ at HF and likely more under other tags. Prime Taiwan. I didn't find a start capacitor in the base, just a chunky switch that allows for 240v wiring. Is that typical?
ching0n
I don't often need transfer punches, but in the past, when I did, I didn't have any. Problem solved.
2-gal Ziplocs come in handy around the shop more often than I can tell. Unfortunately, they're one more thing not carried by any store around here. 100 should last me a while.
HF has a decent deal but I grabbed some myself for same price w/metal holder from Amazon a while back. I wasn't sure if the plastic would wear out over time or if it'd be precisely molded.
ching0n
That table's awesome and one of my eventual fab goals. I've had one for months that's meant to be a welding table at some point but did debate using it for my metal atlas instead.
Beerhippie
Far NE Oregon
The index seems pretty well made. The punches are tight enough not to rattle, but still easy to pull out with one hand.
If I were a more charitable type, I'd drop it on the concrete to give it a durability test--but I'm not.
If the bottom breaks, I'll have no problem marking the screw locations for an aluminum one!
GX460DIYguy
Texas
Haven’t picked it up yet, but I had a friend take an old Mac ratchet to work with him since the truck stops by his shop and it wasn’t working. After a few attempts at fixing it he gave up and just offered a new one as a replacement. Had him grab a 18” 1/2” drive flex head. IMG_1648.jpeg
dscheidt
Still? Awesome! Next question about the modern Japanese car without lifters: does anybody really get them checked? Do the clearances change?
Yes, some of the Honda motors are known for burning exhaust valves. Wear makes them tight, and then they don't have enough contact time with the head to cool. Honda calls it out for 100K, I think. It's probably not done except by cars serviced at a specialist, unless there's a sign of a problem. The people that run them forever tend to do it more often after the first check. And I'm sure good Honda mechanics check if the valve cover is off for something else.
Squankum
Southeast
My hazy memory says that in the old days this was an every-15,000 miles kinda thing? I got lucky, I showed up right after my kinda cars (watercooled VW's) had just moved from bucket shims to bucket hydraulic lifters. But I do own feeler gauges because of some gals I knew in college buying used Civics and Corollas.
Snapped-off
Indiana
I have the marine drivers in my Snap On website online basket - have you bought them for thier intended use (outboard motor gearbox drain screws), and if so which one is the best fit?
I'd probably get the larger ½" driver if just getting one. The smaller one is ⅜", which matches the large flatheads, just a shorter profile. I bought them for outboard plugs, yes.
I figured I'd just get both. It's only money.
dscheidt
Interval has definitely gone up, along with most maintenance intervals and engine lifetimes. VW called out 3k for the beetle, for instance. 100K is approaching the point where many people who buy one new will never have to do it.
I own feeler gauges because I've worked on everything, and they have all sorts of other uses besides valves -- like setting point gap, something else nothing needs! I've used them on valves, points, motor brushes, checking how well components mate, etc. This doesn't explain why I have six sets of feeler gauges, including three identical Craftsman sets, plus a couple spark plug gap wire sets, one of which has very small blade feelers on the other side. One set is a Blue-Point that has steeped leaves -- the blade have about 1/2" at hte front that is 2 thou thinner than the main part, which is handy for testing, when the blades have the gap you want. Another has about 14" long blades, which have come in handy for setting bicycle disk brake pad clearances.
