PelicanPines
Put yellow in red... you get orange... there's that.Well yellow would have clashed. š«£
Good idea. You could expand the hole on a lathe or use a diamond hole saw on a drill press.Depending on the diameter of the vertical pipe, a 25 lb. Olympic weight plate might slide down it.
That's actually a really good idea, I never considered. Thanks!
I did not find anything like that, or else I would have grabbed one. The flat ones seemed to be the thinnest, but do not ratchet.
Brilliant!Cool. I have the same stand, albeit with a lighter grinder on it than you, and I did similar years ago. I also filled it with concrete, and I put two casters and fashioned a foot for the other leg out of a carriage bolt/nuts/washers and a hockey puck. I just tilt mine onto he wheels to move it and once sat back down just the hockey puck foot and gravity is enough to keep it in place while in use.
That's a pic I took when it was new, 8 years ago. I since swapped out the 2" swivel wheels for two stationary 3" wheels, which works a lot better for tilting and rolling around.
IDK about brilliant, but I just hate dealing with locking casters if I don't have to. More like, laziness combined with a willingness to take a chance to see how well it works or not. Plus, I still have a bunch of old hockey pucks that I'm always trying to come up with uses for leftover from raising boys that had a serious need for an outlet to expel some aggression where it wouldn't get me and their mom a call from authorities. lolBrilliant!
The use of the hockey puck as a sturdy and āstickyā base is pretty ingenious IMO. Youāve got me thinking ā¦IDK about brilliant, but I just hate dealing with locking casters if I don't have to. More like, laziness combined with a willingness to take a chance to see how well it works or not. Plus, I still have a bunch of old hockey pucks that I'm always trying to come up with uses for leftover from raising boys that had a serious need for an outlet to expel some aggression where it wouldn't get me and their mom a call from authorities. lol
I'd love to have my grinder on a mobile stand to take it outside; but I'm not sure how to make it stable enough other than a 24" square base that weighs 100 lbs.
Saying that, if you added a bar, or angle, that bridged across the top of the feet between the two casters you could step on that with one foot; that would give you a lot of security against tipping when in use.
Congrats! Same Dewalt saw I've had for years and it gets used a LOT. LUV it!
WAY too pricey for me as a DIY type, but thanks. Appreciate it.Anywho, the main reason I'm commenting is that I just wanted to point out that adding the DWS779 XPS Work Light Upgrade Kit, adding the DWS780's LED light to show that crisp shadow exactly where the blade is going to cut was some of the best money I ever spent.
Fess up, it is the confuse your heirs after you die. Hey anyone know what this thing is?Not exactly a "new" tool to me....more like a "what was I thinking" tool. It's for cutting the top off of an oil filter, so that the insides can be examined for debris after an oil change. I've used it ONCE.
The guys that work on my 911 said that while opening up the filter is OK, they can usually tell if something is amiss by looking at the drain oil itself. If they suspect anything, then they cut open the filter. I'll defer to their 20+ years of experience.
I may hang this on the wall someplace to not only get it out of the tool box, but to remind me not to buy tools like this.![]()
I have one of those too. You donāt need it that often but it sure beats a hacksaw for the few times you do!Not exactly a "new" tool to me....more like a "what was I thinking" tool. It's for cutting the top off of an oil filter, so that the insides can be examined for debris after an oil change. I've used it ONCE.
Checking the oil filters on a 911, and just about all Porsche's, is pretty easy and doesn't need this tool as they use cartridge-style filters.Not exactly a "new" tool to me....more like a "what was I thinking" tool. It's for cutting the top off of an oil filter, so that the insides can be examined for debris after an oil change. I've used it ONCE.
The guys that work on my 911 said that while opening up the filter is OK, they can usually tell if something is amiss by looking at the drain oil itself. If they suspect anything, then they cut open the filter. I'll defer to their 20+ years of experience.![]()
Not if you use a spin on adapter from LN Engineering, like I do.Checking the oil filters on a 911, and just about all Porsche's, is pretty easy and doesn't need this tool as they use cartridge-style filters.
First time poster, long time reader...
After a lifetime of bying tools needed for the task at hand, I've started to clean out the **** and replacing with higher quality tools. I'm aldo going to start redoing my workshop/garage by spring so I thought I would be posting here in training for a garage.thread..
Recieved today:![]()
So yesterday while doing a major clean out and reorg of the truck I reached deep into a door pocket and pulled out a massive concretion of screws, nuts, washers and even a 9/16 wrench. Completely baffled by this mass of metal I started peeling away the layers
And whatta I find?
A Klein magnet. I swear I have zero recollection of ever receiving this highly inductive mystery magnet but sheās a keeper![]()
I have one of those. I like it. Makes it easy to dispose of filters and recycle the metal.Not exactly a "new" tool to me....more like a "what was I thinking" tool. It's for cutting the top off of an oil filter, so that the insides can be examined for debris after an oil change. I've used it ONCE.
