Show your new tool arrivals
cody1325
Southwest Virginia
I got a much better deal on that Jensen 70 than I thought I would have--guy asked $50, but he let me have it for $30.
Needs: smokestack (decorative--since this is electrically-fired), whistle, and safety valve--plus I might as well replace all the seals while I'm at it. Should be about $60 in parts--so under $100 vs. $300 for a new one these days.
They're still hand-made in Jeannette, PA; and parts are available through the manufacturer
Also, I've got more of an excuse to buy the CAT/Williams driver set in-stock at my CAT dealer--I don't own good quality slotted screwdrivers aside from the bits in my old Chapman sets.
To do: email Jensen to see how I test the existing parts, and what other tools I'll need. They do make the specific wrench to remove the viewing glass spanner nut.
cody1325
Southwest Virginia
If you can tolerate an extra half-inch of length, consider these 6.5-inch, flush fastener slip joints from Wilde. They, and their larger cousins, are superb.
Thanks. I've got some of the cheaper Wildes on my HJE list, but not the flush fastener.
Decided I'd try out a bunch of different slip-joints. I love my Knipex 140mm combination pliers (aka linesman's), but wanted to try US-made options.
milkovich
Akron Ohio
Well, I'm finally out of the dark ages! Bonus: I didn't realize it also did UV for leak detection dyes. There are lots of good lights out there and brighter lights, but these are really built like brick outhouses. I'm of an age that this will hopefully be my last or second to last worklight.
IMG_7485.jpgI also discovered that my tool box has a USB 5V output under the 120v outlets!IMG_7486.jpg
cody1325
Southwest Virginia
bench grinder. this is a low-end model (no oil cup) that I might end up cannibalizing for parts. have to sleep on it. CL find.
and a 3/8-16 LH die that hopefully will doctor up the threads on the other grinder. ordered online.
Nice! I've got a pair of them I used heavily as a kid and teenager. Handy as a: variable speed and b: transportable to just about anywhere. Also, it flew by my folks rule at the time of "no power tools without supervision".
They spent many years in a deteriorating shed on a farm we leased. They really could use a full tear-down and restoration. Thinking about changing the nearly worn out stones on them for coarse on one, and fine on the other. Need to get the stones off, and find proper new ones.
Outlier
GA
I really wish I could post pictures here. My order from JB Tools came in today. They had a promo on the drill bits and I picked up a few other items; mostly from Astro Tools.
I needed a rivet nut tool for work and this was inexpensive so I thought I would give it a shot.
Outlier
GA
Almost forgot about the 2020 Stinger. I will be taking that to work to replace the classic Stinger LED I've been using. Minus figuring out a lighting solution for the work van, I'm currently well stocked on lights.
DarryT
A few tools from my first JB Tools order.
3/8 astro nano impact sockets,
3/8 in 1/4 long astro ratchet,
Vessel Megadora Impacta Set
A couple of Sunex stubby wrenches to fill in.
Nice stuff, affordable, impressed with JB.
lund
My two arrivals for the day. The Olsa magnets are for home and the Lisle tool is for work. I sprung for the red magnets. The orange are a few bucks cheaper.
A comment on demagnetization. To demagnetize a ferromagnetic material (steel alloys) you cannot usually do so (except under extremely specific conditions that you will NOT meet) with a static magnetic field associated with a permanent magnet array like the Olsa tool. Yes, if oriented correctly, that "tool" might take out part of the magnetized alloy field. But it is unlikely to take it mostly out and very very unlikely to take it completely out. Plus if you insert something magnetized (say screwdriver tip) in it pointing the wrong way (just rotate the blade and you will do this) it will then enhance the residual magnetic field to make it *worse* in the sense of being more strongly magnetized up to the material limit. The proper way to demagnetize something Ferromagnetic is to insert it in an oscillatory-current driven electromagnet that is slowly driven (slow here in the sense of material response times which is fast by our perception) while reducing in drive (coil current) amplitude to zero. This should almost always leave the Ferromagnetic material to a state of very low residual magnetization (meaning demagnetized).
I recommend that people avoid buying such a junky "demagnetizer". I feel it is irresponsible for a company like Olsa to sell something like this as a "demagnetizer". Whiha sells something similar. Both border on false advertising. Unfortunately, demagnetization is not so simple.
I looked up a cheap device that *could* work as a demagnetizer for small tools on Amazon. Something like:
is not precluded from working by materials science/physics. It is possible to make more substantial demagnetizers with a driven circuit electromagnet, but that would be expensive and a lot of trouble. I did NOT buy the instrument in the link above so I cannot promise it is quality. But if anyone has one let me know if it works ok on screwdrivers etc, and I might buy one myself.
By the way, the reserse process of manetizing a screwdriver tip or tool is pretty simple. You can just inset the part you want magnetized in a strong dipole magnetic field (say from a permanent magnet). Unfortunately, demagnetization is much more involved.
I hope this helps some people. My late fater used to ask for stuff like this and buy tools like the Olsa device and then he would complain about them not working. He ignored my explanations (thanks Dad!) and an offer to build what he wanted. He tried a few iterations of devices like Outlier showed. None came close to working as one would expect from basic principles.
Outlier
GA
@lund
For the things that I do, I don't think I've ever worked on or came across anything sensitive enough that would have absolutely required demagnetization. Just thinking about smaller electronics, I generally keep separate tools for that kind of stuff. Good info all around I will be more mindful of that in the future.
Outlier
GA
This came in late last night. Unfortunately, it will be going back. I had hoped they would be the older-style locking extensions that Proto and the tool truck brands use, but they are not. It's a shame too as they came in nice green and black foam organizer.
LXCam
^ Those look like a poor excuse for
They don't make 'em like they used to.
I definitely wasn’t expecting those in this price range and the screwdriver handle was a real good hint they weren’t heavy duty.
Before making my post I only played with one of them. The quick release feature was insanely notchy and the screw clamp rough which I’m sure some lube will take care of ( hopefully).
But after posting I grabbed the other model and it worked very smooth. I’ll **** around with them in a couple days and see how it goes.
Steve_P
Zoro says they're USA made and it looks like they show the "old" SK USA locking style, like Proto also used, in the picture. What did you receive?
Fedwrench
Valley of the sun
What's different about them? can you take pictures & post them before returning them? Did you order them from SKtools.com as part of their 30% off sale?
Outlier
GA
@Steve_P
I will try and post a picture of them if I can. For some reason, I can't seem to post pictures here. I did not get them from SK. I got them from Zoro and used a discount code.
racer1735
Canyon, TX
Does this count? In the past I've used a small four or five drawer tool cart that I would roll to either my bike or car, but I've found that so many of my projects involve using a laptop or having a repair manual close by and those tool chests don't afford that opportunity.
FigN⋅m
I am truly stumped on why I can't post pictures. This was the only other thing I knew to try.
Trying not to clutter the thread, but are you attempting to use the little image icon (Ctrl. + P) or the Attach files button?
Choose the image from your album and right-click it to copy the image address.
Use your post's "Insert image" icon button and then click the little chain-link "by URL" instead of Upload Image .
This will give you the field to paste that image address from your album. Here's the 1st image from your album:
WNYflyer
Lockport, NY
Shout out to Proto/SB&D. Picked up a couple years ago a set of used Proto reversible ratcheting wrenches which the style has been discontinued for awhile I guess. Well I have a thing for wrench/tool- pouches/rolls so I contacted Proto to see if they still had the associated wrench roll available since I didn't have it. Well the lady at Proto/SB&D kindly sent me the wrench roll free of charge, yeah baby, and it probably helped that the wrench set has been discontinued. Photo of the newly obtained wrench roll and a photo of the wrenches in their new home.
full
cody1325
Southwest Virginia
full
Nice!
I'm getting a full metric set of ASD from the mine supply, but they don't have them in full sets. Thus, I'll have to probably do the same.
I've got the rolls from the '60s, but they came with incorrect wrenches ( HTD Japan-made Metric--which so far, are my good metric wrenches) and the vinyl has hardened, thus they aren't great for daily use.
Semi-hole mechanic
I do as well.
WV has a couple, but the closest is a three hour drive for me. Thus, not really worth it.
If they follow Rural King's expansion into Southern WV and SWVA, it would be great. But, they don't have one thing working in their favor that Rural King did--loads of ex-Sears and Kmart stores landlords were basically begging new tenants to move into.
Other than new construction, I couldn't think of any other way for them to get new stores in my area.
I don’t think Menard’s ever leases or buys already built buildings. Every one I’ve ever been in has always been new construction.
david3921
Wyoming, Michigan
I really could use one of these but I just can't justify the cost. Most I see are $100 or more.
lund
@lund
Some (me included) do not like the residual field of magnetized screwdrivers, wrenches, etc grabbing stuff like metal shavings. With some electro-mechanical stuff (hard drives for example), one should avoid bringing magnets near them even then the field magnitudes are not that large. Most solid state electronic devices are ok with modest fields
Scientific labs will demagnetize large electromagnets for charged particle optics before adjusting the setting since if that is not done it can impact the precise strength obtained when you adjust the coil current. This is way outside the scope of most host home uses.
