Show your new tool arrivals
Nobody-named-Olli
UPDATE: Large HF wagon. The wagon was well packed with all the parts present in the box. Nice and clear instructions made for a straight forward, easy and quick assembly. Its a bit heavy and bulky when lifting so if you have a bad back, might want some one to help carry it or use a hand truck.
Wheels are held on with one flat washer and cotter pins (would be better if they were E-Clips) Axles are a slight bit longer then necessary so I'll probably add another one or two washers to each end of the wheels to take up the slack. Comes with a thin, near perfect fit rubber mat for the bed.
The sides fit pretty good all round. The lower sections and clips line up nicely and all four of the side's when raised are held together with quick release latches allowing the sides to drop down or come off quickly as needed. NOTE: the front side has a 'v' cut out to allow for handle clearance, however, if you drop the sides down while leaving them on, the turning radius is limited some, even more if you drop the front side down as the handle hits the side of the 'V'. Tires have a max 30lbs air pressure and that's what I filled them to.
The handle is of a two piece type. A pin allows for quick removal of the hand hold revealing a 'U' forked end for attaching to a lawn tractor for trailoring. Overall it's pretty solid with decent welds and a nice powder coat paint finish, although I wish they would have painted the wheels orange too....maybe I'll do that down the road. Is it HEAVY DUTY?, well lets just say for $136.00 bucks (Members Sale Price) it'll do just fine for your average home DIY gardening tasks.
We have that same cart, probably all coming from the same factory, been through a lot and it is holding up. Issues over the years: Tires & very, very thin paint = rust.
We've used ours to handle a couple of hundred pounds of various brewery things over the years. They aren't the HF brand--got 'em at ACE--but sure look identical other than color.
The tires they come with are "run flat" tires--meaning if you want them to run, they're flat. I replaced ours with foam-filled tires and never looked back.
I know I've had to do some welding on the various parts over the years, but don't recall just what--and we did used to haul loads of grain and hops of 200+ pounds.
Absolutely agree, swap the tires. I’ve been through the original and two spare sets before making the switch to foam filled. They are on for a couple of years now and no more issues. The only ‘issue’ I have with those we purchased, they are not rolling as nicely as air filled tires - especially under heavy loads.
But again, it’s a very, very useful cart. Would buy another one in a heartbeat, we use it at least twice a week.
Kind regards,
Olli
jgeoffr
A quick look on The, Jungle says $66.
At $40, probably in a heartbeat but I am bidding on a couple of other tools
I spoke to the guys at HJE a couple of weeks ago about these. Looks like they are now in stock!
L.Cheapo
Me too. A local store has them for around $50.
Weren’t they on sale for around $40 recently somewhere.
They were on sale for $43 a few weeks ago on Amazon...until we, the esteemed members of GJ, bought them all. :ROFLMAO:
WWheeler
Middleofnowhere USA
That sale price for $43 on Amazon for the Lang long pin punch set seems to keep coming back very briefly every couple weeks, but you have to be fast before it's gone again. I missed out on the first go around (Mar 17) so I set up a CamelCamelCamel alert for any price drops under $45 and got an alert (Mar 31) and my set a few days later. When I bought it it was the only one available at that price. Since then I've had a couple more alerts. For example, I posted about one here on April 11.
WWheeler
Middleofnowhere USA
Found trying to screw on my inflator's straight chuck on my mower was a a slight PITA to do because the hub was in the way. Had to pry the valve stem over a bit just to get it on there. That got me looking for an angled chuck for it, and settled on this. Works great. No more having to screw it on or off at all. It just slips on and seals and when done press the button and it releases. Makes my inflator much easier to use.
JACO Lightning L2X tire inflator self locking nozzle.
mikeinri
I have one of those on my Milwaukee inflator. One of my favorite buys, ever. Especially for modern inflators with presets and automatic shutoff. Just clip the chuck on, hit go, and watch it do its thing...
I did learn to pay attention to the position of the hose and release, especially on my Buick, which has valves that barely extend beyond the holes in the hubcaps. You want to be sure you'll be able to get a finger on the release after filling.
Mike
PugetDude
Superstition Mountains, AZ
Ditto. I have no experience with the Felcos, but if you're using straight blades to cut a cable, you can only expect it to squash the ends, as the wires get pushed outwards while you're squeezing to make the cut.
Mike
Midwest makes a great aircraft cable cutter. Clean cuts, no deformations.
Squankum
Southeast
Well, my "new tool" hasn't arrived yet, but I do own it.
I buy from online auctions, I'll sometime monitor the action to follow hammer prices as they don't publish the hammer price after the auction is over. To keep tabs on going prices sometimes I'll place a low entry bid, fully expecting to lose. But by placing a bid it allows me to see the hammer price well after the auction is over.
I was going to be offline for most of wednesday, so I put in entry level bids on a couple of items. Shockingly, I won both, apparently the auction was not well attended. On the plus side, I won a stacked Kennedy roller set. I can use those two boxes. But probably not the tools that come with it!
What I was not ready for was winning an 11" metal lathe on a base cabinet. Totally out of my skill and knowledge set here. The auction has a single rigger they allow you to use, and this rigger is not an option, I was quoted an absurd price to just have them load it on my trailer. So I'll likely break this down into manageable pieces to get it out of there, onto my trailer, and into my <gasp> basement shop.
Spent a bit of time on Vintage Machinery today, downloaded a couple manuals. It has variable speed, so I'll need to take a few parts off in the cabinet underneath to get the drive belts off the spindle assembly. It's not the lathe I would have chosen, but in my preliminary research the lathe itself is well regarded, though parts can be hard to come by. Hopefully I won't need any.
Delta Rockwell 25-100. At 11" it's big enough, but not too big. I'm a hobbyist. Seems to be a good lathe if it's in good shape. If not I'll figure something out.
I'm sort of excited. And also a bit scared! This is NOT in my wheelhouse. Hopefully I'll have a good story to tell and a few photos to post Monday.
Have a friend who picked up an old Sears/Atlas lathe. Two things I learned:
a) read up on safety/what not to do FIRST!
2) You may think you might use it for two or three things, but you'll find yourself using it for lots of things!
Squankum
Southeast
I just spotted at least two of them available separately at HJE, and the set for a fair price, too:
BlakeTheCarGuy
Roanoke Virginia
A couple new arrivals from eBay today. First a vintage and well seasoned Blue Point ball peen hammer 12oz. I’ve noticed 12oz ball peens are hard to find but it’s one of my preferred sizes so I didn’t have one at work just had one identical to this at home so I purchased this one for work. Then a Toyota axle nut unstaking tool from eBay as well.
Outlier
GA
A little late, but the tool haul for the week. Some of these came from JB Tools on clearance and I just couldn't pass them up. I think one or two of them someone else posted not too long ago.
*Edited to add that the extractor set I received came in a pouch more like what the chisel and punches come in now versus this older style clear vinyl.*
A Knipex haul from Amazon.
This last one I have been looking at for a while now but never pulled the trigger on. It has gone up in since i first put it on my wish list but I came across a good price for it on Ebay and they happened to be having some sort of promo so I got another 20% off with free shipping. I think total was just over $100. SCORE!
Squankum
Southeast
Schley are good folks!
Squankum
Southeast
Adam Savage has sung the praises of automatic wire strippers in general, for years now. Recently, he has declared his Knipex to be even better.
His is slightly different from yours, I think:
Outlier
GA
I have a Rennsteig branded pair of those. I find they tend to only work well on heavier gauge insulated wire.
KYToolz
Southeastern Kentucky
This arrived today. I was browsing on eBay last week and saw a replacement adjustment wrench for my DeWalt DWS780 miter saw and ordered it immediately. I lost mine last summer and have been wanting to get another one ever since. I have a screwdriver in this size that I carry in my tool bag, but I like this much better because it stows onboard the saw.
KYToolz
Funny, I think can remember hearing the name Adam Savage once or twice, but I had absolutely no idea who he was and had to Google him!
Squankum
Southeast
My son was a huge Mythbusters fan in grade school. His mom (my ex) took him to see Adam and Jamie at Truman State University when we lived in MO. He was 10 and got to ask them a question during the Q and A portion of their talk.
Neat! Let him know about Adam's YouTube channel, as he often gives behind the scenes stories about MythBusters experiments. He also talks about tools and building things and other neat stuff.
Here's his story about working on the movie Space Cowboys. After the production was over, Clint Eastwood gave everybody on the crew a bedroll. He loved it, used it for 20+ years but it got stolen, so now Savage Industries is making their own for sale.
Clint likes the Butler brand, made in Cedar City, UT.
Just an example of one of the many zillion things Adam gets up to.
Squankum
Southeast
OK, back to tools! Got these recently:
Channellock 908 wiring tool, Knipex 10" pliers-wrench, 7" dikes from Ignatz Igance.
Hey, those aren't pliers wrenches! Amazon warehouse boo boo! Super duper wiring ferrule crimpers:
I wonder what those cost?
Ay caramba!
That's not what they charged me. Are the gears in your head turning, too?
The Igance pliers are the same company that made those $7ish flush cutters everybody (including me) was buying this past winter. I was so tickled with mine that when I started building my on-the-road tool bag and wanted some dikes, well, they aren't 8", only 7", and they're made in China, but at $9.99 I figured I'd give them a try.
Squankum
Southeast
More shop supply than tool, but to go with the Channellock stripper/crimpers, I wanted an 3M wire connector assortment for my tool bag. And that turned into a bit of a hunt. I could have sworn these used to be sold at Wal-Mart, auto parts stores. I didn't find it on Amazon and I didn't see it at Wal-Mart, and Wal-Mart.com, like Amazon, showed such a thing but no longer in stock for quite some time. Did something 20% cheaper and 30% worse* push them out of the market? I got this as NOS on ebay. Other searching indicates that 3M most certainly is busy in the connector market, just not these retail assortment packs.
Knipex 10" pliers wrench with the comfort grip my big hands crave.
$30ish off ebay, a new Buck 110 Slim Select. Much to my surprise, I was expecting at that price point (MSRP $42.99) they were just slapping mass-produced (very mass produced!) 110 blades into a cheaper plastic handle, but besides the obvious thumb stud, this blade is just under 2mm narrower (talking width, not thickness.) Blade finish is different from my 2000's era 110, too. Shape is a little different, too. Maybe it was the $20ish Buck 110 with plastic handles Wal-Mart sold here and there that was merely a regular 110 blade into a cheap plastic handle.
Nothing about this one feels cheap. OK, it came in a box like it was new, new papers, but the box was for some totally different model. OK, I ordered it from Some Guy on ebay. Or it's a counterfeit. Seems really well-made to me. Sharp, too.
________
* This, boys and girls, is how "cheese food" came to be. And people buy it!
KYToolz
I went to Harbor Freight this morning to pick up a Central Machinery concrete mixer for an upcoming job. I researched it quite a bit on YouTube first and, though it has some quirks, everyone seemed pretty pleased with it for small jobs, which is what I will be using it for.
While I was there, I also picked up an Apache 4800 case. Since it has the pluck out foam in it, I can form fit it to all of my DeWalt 20v batteries and have a protected way to carry them. I also found a DeWalt sticker on eBay that should cover the Apache nameplate on top perfectly.
kyrbz
midwest US
I've used the same one for many projects. The only issue I've had is the key that holds the gear that turns the drum has vibrated out a few times. The first time it happened I couldn't find the key and it almost messed up what I was working on. Had to mix several bags by hand to save the project. Now I keep a few spare keys on hand.
boom_bap
Idaho
Thats a 110 slim select, you can get it from buck directly too for that price, Its not a knock off. They are awesome little edc knives. I like the 112s myself.
KYToolz
Did the screw and washer that holds the key in place vibrate out? A guy talked about this in one of the videos that I watched and he recommended putting blue Loctite on the screw when you assemble it. I’m planning on doing this when I put it together tomorrow so, hopefully, I won’t experience this problem.
KYToolz
The FedEx guy showed up this morning with a package containing a Milwaukee aluminum framing square, a Milwaukee ratcheting screwdriver and a SharkBite PEX ring remover. I got the square to replace my steel one which is starting to develop some rust. I’ve also been wanting a square that has contrasting markings because these old eyes of mine were having trouble reading the markings on my old square. As far as the Sharkbite goes, I’ve slowly been replacing my plumbing tools since last fall when someone decided that they needed my plumbing box more than I did! 🤬
The mailman showed up next with a tool I’d been wanting for awhile. Any idea what it is?
It’s a FastCap knuckle bender tool to adjust doors with. The pin on the bottom is used to remove the hinge pins.
