Show your new tool arrivals
Strouty
Southern Maine
I think so far that its very good quality. Nice heavy beams and crossbars. This one weighs quite a bit but can I barely feel it being towed. Also the rear ramp/door is constructed from 1/4" thick angle iron. Other ramps I've seen where made from only 1/8" angle.
Just make sure you balance the load, most of them I see built into workshops have ⅔ of the weight in front of the axles. :willy_nil You will feel it if you load it like that.
dodge610
North Canton Ohio
Not to steal the thread Strouty but I got the managers job at the large auto parts store. Gave up driving truck back at it again in a week that is.:D
Bobcat753
New Hampshire
Yea most of the time it will be in the driveway. Don't have a whole lot to put inside yet, but that will change:evil:
Tomorrow is when the big order arrives some nice new blue goodness:rocker:
CastleBravo
Lynchburg, Virginia
New to me, steel work table. I think it's a Lyon. It has this cool channel built in for power. I've only got two outlets installed at the moment.
kunkernator
US of A
Looking good on the welding.
Thanks! Im really no expert on welding, so that means a lot. I used my oxy torch and fusion welded those, didnt need any filler rod. :thumbup:
BTW, that is the torch set you recommended to me a while back. Has gotten tons of use, heating, welding, and cutting! I love it!
jeopardy98
Prince George, VA
Thanks! Im really no expert on welding, so that means a lot. I used my oxy torch and fusion welded those, didnt need any filler rod. [emoji106]
What torch are you using and what size tanks?
kunkernator
US of A
I am using a full size O2 tank (330 cf?) and the second largest acetylene tank (200 cf?). A while back, Strouty recommended me a Smith torch setup, right after i got the tanks. It was the entry level Toughcut torch, and Series 30 regulators.
I am VERY pleased with them. The torch came with a brazing tip, welding tip, and cutting attachment/tip. There are MANY other sizes available for the handle.
I have gotten so much use out of the setup since i got it. It helped me immensely when i was replacing the rear bedside on my flatbed.
jeopardy98
Prince George, VA
Thank you very much! I'm currently trying to make heads and tails of all the choices out there for exactly this. I don't cut too much but do sometimes need to cut a motorcycle/atv frame or swingarm or an axle. Having the option to weld and braze would be great.
RatZ1LLa
Rat, those are awesome. Did you get a good deal? If so where did you get them?
Yeah they are sweet, as far as a good deal not really just bought them straight from CountOnTools. I wanted to get a really good set and I think they are worth it to me.
wiens80
Needed a good torx driver set. T15 - T30.
Also got these Gray flare nut wrenches. Canadians, take note - these things are every bit as nice as Snap On/MAC flare wrenches- maybe even nicer. Seriously, I have never seen a more 'perfect' set of wrenches haha.. sounds weird to say but they are literally flawless. Can't wait to use them.
Love those Gray's.
uglyjacko
Mexico
Today's local CL find all for $140, all are getting cleaned up and ready to go back up on ebay.
Ingersoll rand 2135 ti, ingersoll rand 2115, cornwell car1000mrr, cornwell cat4050sdr, blueproint at118
kunkernator
US of A
I saw your post on the acetylene tank you bought. Like some guys said, that is for brazing/heating. You cant cut without oxygen.
This is the exact set i bought, from the same store. Just pay attention to the acetylene fittings (i believe smaller bottles use the CGA 310, larger use the CGA 500, as it is available in both options).
http://store.cyberweld.com/smwecuoutomb.html
Do a little bit of research on owner bottles and rentals, especially if you are buying used (if you accidentally buy an old rental bottle, nobody will fill it because it would be considered "stolen"). Also make sure the hydro test is in date. It more matters on the O2 bottles, but you will not beable to get the bottles filled if they are not dated.
A quick Google search can go more in depth in all this information.
Just to give you an idea of pricing, used full size O2 bottles normally go for about $200 around here (owner bottles) and similar pricing for acetylene.
If you are doing cutting, remember, you will be using more oxygen than anything, so the bigger the bottle the better (from what I would guess, if you only cut, you will be using 2-3 bottle of oxygen to 1 bottle of acetylene).
With all that said, do some more research and then go hunting for some bottles. I am also sure you could find a good torch/reg setup on the used market.
If that bottle you bought still has some fuel in it, play around a bit. Nothing like playing with fire!
90zcar
Guess VIM isn't putting the triple square set in a plastic case anymore?
Nice either way. I threw my case out anyways
DieselJH
Richmond VA
Well when I ordered this it was between this set and another VIM set with the plastic blow molded case. This set has the 18mm where the other did not. These will be going onto a rail in my toolbox so I didn't need the case. This set was alittle cheaper as well.
kunkernator
US of A
Got these on special off the Mac truck. $85. He even let me switch the chrome 3/8-1/2" adapter to the impact one you see!
Bobcat753
New Hampshire
Miller Trailblazer 325 EFI w/Excel Power arrived today! What a machine nice and quiet plus it welds like a dream :D Now to start making some money:rocker:
Also the Miller Suitcase Xtreme 12VS arrived. Still waiting on the drive rolls so no run time yet.
M6erfan
'Merica!
My first Tekton tool, 12" 3/8 breaker. Made in TW if anyones curious...
Looks nice, chrome is good, no defects that I can see. I immediately took it apart and put a little oil on the detent ball/spring and added a drop of Loctite to the 4mm hex screw.
kunkernator
US of A
You will be well pleased with those. I have been using them for a few years now and not a lick of trouble.
VIM triple square set, HF earmuffs for use with my louder air tools, and a cheap auto parts store tread depth gauge.
I own them as well. Very good bits, have torn deep into many VW's with those. Love them!
rockinacummins
Wapanucka, OK
Very nice machine! Did you buy it new? And what is the price on one if you don't mind me asking?
Skin
Boston
Knipex XL (16") Cobras to compliment my 10".
And, very exciting I know, a Hazet Ball Joint Separator
had some other things but they decided to jump out of the box in transit.
Fedwrench
Valley of the sun
New Tekton trilobal screwdrivers. Flat 3/6 x 4, 1/4 x 4, Phillips: #1x 4, #2 x4, and #2 x 8. Nice US Made screwdrivers that are pretty reasonably priced. I'll beat them up at work and see how they hang. They have a bimaterial handle but, the rubber section is almost as hard as the red plastic portion. There are three different handle zones, narrow almost round towards the front for finger spinning, then two gradually thicker trilobal handle sections. Size and type of blade are stamped on the top of the handle. :beer:
