QuadCamBastard
- Joined
- Jul 30, 2013
- Messages
- 17
i have had that ratchet for about a month and i love it
.....I don't know much about US market Toyota's so I only found 2 V6's. If it's a 5VZ-FE (3.4 litre) you need AVSA-073 (72.5 mm, 14 sides), for the 3GR-FE (4.0 litre) you want AVSA-064 (64 mm, 14 sides).
My 2008 Toyota Tacoma has a 6 cyl. 4.0L....1GR-FE....engine. I only use a Mobil 1 M1-102 oil filter, the spec's for this particular oil filter are as follows:
Outside Diameter (in.).........3.62
Height (in.)........................3.15
*Source of reference information: http://www.autozone.com/autozone/parts/_/N-5yc1s?itemIdentifier=106092
EDIT** Found this info: http://en.ktc.co.jp/products/catalog/pdf_cat/Engine.pdf
It appears, according to the chart given the first number and letter of the engine under Toyota, as though the KTC oil wrench filter tool would be part number: AVSA-073 ?
1G, 1JZ, 1MZ, 2MZ, 1N(-099 may be used),
1RZ (-095 may be used), 3RZ, 2JZ , 2TZ, 2UZ, AVSA-073
3VZ, 4VZ, 5VZ, 5V, 7M
If that one is what you mean then that is from a different engine series.
However, if your standard filter was a 90915-20004 - which seems to be the standard fitment for 1GR-series engines - then the AVSA-073 is the right wrench for it.
Are you sure about the size of that Mobil filter? From the pictures it doesn't look like it's that wide.
Great deal on Amazon for these. I needed to add to and upgrade from my 12 pt set.
Craftsman 40oz. Blacksmith Hammer (Made in USA)
Added to my hammer collection today...
is that sku# 80565? amazon shows a 6 pt kd by gearwrench set for $30but the gearwrench site shows a 12pt set under that #
.....unless i read the part # wrong
Where did u get that 8pc set of green screwdrivers?
The Klein bottle opener is top notch, I have one myself![]()
Nice pick set, you're missing some drivers though!
Got a corn well driver today. Here are the first things I bought from him.
Master Mechanic Made in USA Vise Grips
eBay.
