For $19.99 that's not a bad deal at all!
Did you also get that from Amazon?
Really like the supplied rack they came with!
The new Wiha Picofinish 4mm bit handle does fit in their super handy little tin can set. It closes.
View media item 98381
KS Tools locking flex bit ratchet (basically the Facom/USAG one with a different handle and lower cost):
Nice setup threadkiller. Prepare to spend $$$$ on tooling![]()
Threadkiller, Nice 500 pound mill there. I'm jealous.
Ha, i know....At least it came with some brand new 2 and 4 flute end mills. That should hold me over for a short while. Oh it also came with a set of R8 collets
Ha thank you. Believe it or not its actually 600lbs. I did'nt believe it until I saw it in person. Its gigantic.
How are the handles for Wiha micro bits? Keep meaning to try one but they are more expensive here than in the the US.
...and any idea what 'Joggle' ratchet means?
https://www.kstools.com/en/products...with-plug-adapter-for-sockets?number=918.1590
Basic acquisition list if you intend to start using it:
-dial indicator with mag base. You’ll need this to indicate the vise along with a ton of other uses. Very important as you have a round ram, every time you move the head you’ll need to verify.
-edge finder- self explanatory.
Every other tool need will show itself depending on the task. Have fun! My brother has made some incredible parts on a Rong Fu.
Thanks. I had to buy one too!
Nice find and purchase. If you want help with it there is a Rong Fu group on the Hobby machinist forum. Many owners there and super to learn from the many professional machinist and hobbyists. Truly a friendly forum.
Roy
Hauled home my $500 skidsteer tonight. Only 23,000 hours on it. Runs and works good
Who makes that screwdriver rack?
23,000 hours?
Translates to 1,230,000 miles on the odometer
I think I'm finally done buying ratchets
Sent from my Pixel 4 XL using The Garage Journal mobile app
Probably a mess. Repairs get real expensive real quick.
23,000 hours?
New to me saw and brand new batteries.
Why only $500? Was it a buddy deal or something?
Actually it's in pretty good shape. Runs good, hydraulics are strong. Axle bearings are tight. Drive chain slop is acceptable. Brand new bobtach and pins. No electrical problems. Pretty much all it needs is one tube line with a pin hole leak, steering repaired since it creeps and the rear door is a bit funked like they always are.
