From Zoro with a coupon. A little pricey but they're USA-made and I needed the larger sizes more than anything. Only used them on two jobs so far but the spline box ends actually work.
You won't regret them, they feel nice in the hands too. I bought them from Zoro, but back when they had 30% off coupons, got the metric set too.![]()
I have gearwrench, SK X-Frames, a few wera ratcheting wrenches, and the Proto USA made ratcheting wrenches. The proto are the only ones that have ever locked up on me, and its been in very low torque situations when they were practically brand new.
They've been a disappointing wrench to me, especially as I went out of the way to spend quite a bit more for a USA made ratcheting wrench. Hope your experience differs.
I have the wera and x frame, how do you like those?I have gearwrench, SK X-Frames, a few wera ratcheting wrenches, and the Proto USA made ratcheting wrenches. The proto are the only ones that have ever locked up on me, and its been in very low torque situations when they were practically brand new.
Wera stainless drivers and regular nut driver set
Sent from my SM-N975U using Tapatalk
Nice set! I ended up going with Felo but I have also been wanting to get a Wera set. I think I have a problem.
Kaizen foam lift out layers. Expensive but worth it.
Did you put any backing on them or are is the foam itself rigid enough to use like this?
I have FELO, WERA, VESSEL, XCELITE and SK Softgrip. Various sets, screwdrivers, torx drivers, nut drivers, and hex drivers.The thing about screwdriver type tools is the cost is not bad so you can afford to experiment and collect. I may add some PB Swiss jut to see what all the fuss is about. And some WIHA precision drivers.
Hello, which of your screwdrivers you like most and why? Thanks
Got new graspers:
That is neat! Do they work well? Where can I find more information/source?
Thanks.
Knipex 09 01 240, these things are monsters. Saw them cheap on Amazon and figured what the hell.
Got new graspers:
how do i make pics larger so u can make out whats n the pics? still havent figured that one out. just learned how to post pics in the message last week
Nice find those look better than the claber and gardina ones I use.Hopefully these brass Gorilla Easy Connect for the garden hose last longer than the cheap Aluminum ones form Lowe’s.
Sent from my ONEPLUS A6013 using The Garage Journal mobile app
