Speed-Racer
- Joined
- Aug 25, 2008
- Messages
- 736
Nice Aircat!
I've had the ones from HF for as long as I can remember but they are 2 seperate tools, one with the claw grabber & the other magnet. I'm down to my last pair so I've been meaning to get more. Never knew they make them now with the claw & magnet in one unit.
I like the General models, 4 claws and an LED, 24" and 36" models available. It always seems to be dark down where the lost/dropped thing is, so the LED really helps. They run about $10-$11 at Amazon.Unfortunately none of the Walmarts around me has it in stock & through your link order for pick up is not available. Found one on Amazon for $5.59 so I just ordered it. Says it has an LED but I don't think it does & I actually hope it doesn't. The ones with LED looks different & they cost more.
Just curious where you ordered from. Thanks.
Recent acquisitions! The router table, planer, c-clamps, and screw driver lot came from a local estate sale. The Stanley adjustable t-bevel came from an antique store and impact driver from eBay
Indeed vintage Cee Tee... Jamestown. Crescent Tool. Now I'm curious why they used that branding...Not new, but new to me...
Grandpa passed away many years ago, but I just got around to seeing what tools were left behind.
I've heard of Cee-Tee before, but haven't seen any until now. I haven't come across any Vise-grips without the release handle before. The adjustable wrenches look pretty standard - The monkey wrench just says "AUTO" on it.
Now those look very handy!Not a very frequent use item, but I sure needed one a couple of weeks ago.
How loud is a small unit like that?UPS delivered my new air compressor! Super excited to finally get a Rolair AIRSTAK to compliment my Bostitch and Festool gear. The little compressor comes up to pressure pretty quick and will certainly fit my needs as a brad/pin/narrow crown stapler air supply.
Well that’s a good question. The outside of the container has 95 dB LWA posted on it and the manual has 70 dBA posted on it. In my small basement shop it’s quiet enough to have a conversation. And full pump up time (0-125 psi) is only 32 seconds with a recovery time (95-125 psi) of 9 seconds. So it really doesn’t run long either. Time will tell how well it does but I’m only using it for pneumatic nailers.How loud is a small unit like that?
That sounds bearable, might need to look into something like this when I am doing work in the house. I have a smaller kobalt compressor that takes a little bit to fill up but it isn't awfully loud.Well that’s a good question. The outside of the container has 95 dB LWA posted on it and the manual has 70 dBA posted on it. In my small basement shop it’s quiet enough to have a conversation. And full pump up time (0-125 psi) is only 32 seconds with a recovery time (95-125 psi) of 9 seconds. So it really doesn’t run long either. Time will tell how well it does but I’m only using it for pneumatic nailers.
There are much less expensive options available that fit in a similar format. I specifically bought this one due to the Systainer format. At $475 for the Rolair it isn’t a bargain by any means.That sounds bearable, might need to look into something like this when I am doing work in the house. I have a smaller kobalt compressor that takes a little bit to fill up but it isn't awfully loud.
I did that also from my garage into my basement from my 5HP 80 Gallon Champion. I bought this because I recently sold my large compressor and wanted a small portable unit. The other compressor was way over-kill for my needs and took up too much space in my garage.Yeah for 475 I can probably plumb an airline into the house from the wife's garage and not worry about noise at all haha.
