Signet Tools 10 Piece Extra Long Combination Spanners
JBradley500
First, let me say I do NOT need any more wrenches and I’m just asking out of curiosity...
Is this brand a low end brand? Where would these have been made? And lastly, how long would these be?
I saw a tool box tour where a guy had a set, but I can’t find anything about them.
rmsg0040
Toronto
Signet just rebrands, most of their stuff is gearwrench
Warranty will be a pain, I tried to warranty a ratcheting wrench for a friend, they wanted me to send it in for inspection
They are based out of Pickering, Ontario
Once a year they open the doors for the public for a 3 day sale, other than that you have to buy through a distributor
Don't waste your time
Moose Legs
Edmonton AB
They are a mid grade taiwanese brand, mostly sold in bulk to industrial companies, along the lines of westward, procore, and jet. Their wrenches aren’t actually the same as gearwrench, at least not any more, but pretty much the same in quality.
dutchgray
Dorset. England.
Got a single Signet spanner, a 16mm, they are long, quality is ok but nothing special, picked it up used for pennies as had a cheap set for abusing or lending out that was missing the 16mm, not that 16mm gets used much by me. You do see some Signet about in the UK from your usual cheap tool sellers, the mobike vans and the guys that sell at autojumbles etc.
Mr_B
Reading
They nothing do with GW or Halfords Pro .
As others have said they mid range taiwan, some stuff better than others but generally well over priced and same or better easily found in same cost range .
Markoos
South East England
You get what you pay for..
I have a few, can only recommend stubby 3/8 qr ratchet and chrome extensions.
Do not buy spanners, brake pipe - had two failed- on one all chrome pealed off, another cracked for no reason and was replaced by warranty, one extra long ring spanner (14mm) replaced 3 times due to being machined off centre and cracking, last replacement was ok.
As above, be better off with halfords advanced line...
Dakkyz
South Yorkshire
I believe these are really thick spanners the ones I bought a few years back using the open end I have noticed the jaws look like they're flexing which is a little scary.
There is better brands out there for the same if not cheaper.
Sent from my SM-G950F using The Garage Journal mobile app
Mr_B
Reading
Yeah in uk for long pattern you want be looking at Stahlwille and Toptul
stahlwille open box 14 is world class quality wrench and set ordered online can be very cheap for what is some of best spanners made .
Toptul longs are really long and again amazing truck tool type quality at no more than those signet ones.
Halfords is pretty weak on tools, range very limited and I not seen long pattern wrenches in the range ...
sberry
Brethren, Michigan
This is something that i do use outside of basic combo and part of an advanced tool set. A quite a few times i find myself reaching for them as the "right" tool for the job. Sometimes on the front of car engines and working on machinery.
It's something not everyone needs, it's not in the first tools class, it could be for special apps but most serious tool collectors and professionals have a set,, maybe 2 like I do. Mine are old cman and brutally tough.
Cman makes 2 different sets or 1 big one with a different size on the big end.
I don't even own a set of stubby, I cut off an old 1 or 2 when there was no other way, really rare for me not to be able to use something common.
Same for sockets, a thousand common ones, only a few speial, not every one they ever invent.
sberry
Brethren, Michigan
I have tubing wrenches, a small set of snap 6 flanks, a small set of C jaw deals with a hinge on them that are used on rare occasion, the longs and really only recently a set of ratchet from Sears that are again used rarely as problem solvers and about 500 common combo that are the workhorses. In impact it is all 1/2, used a lot.
If I was a real specialist wouldn't be scared to add omething I used regular.
Mr_B
Reading
To answer the length part of OP question:
10mm Extra Long Combination Wrench 188mm long,
11mm Extra Long Combination Wrench 206mm long,
12mm Extra Long Combination Wrench 224mm long,
13mm Extra Long Combination Wrench 242mm long,
14mm Extra Long Combination Wrench 260mm long,
15mm Extra Long Combination Wrench 278mm long,
16mm Extra Long Combination Wrench 296mm long,
17mm Extra Long Combination Wrench 313mm long,
18mm Extra Long Combination Wrench 332mm long,
19mm Extra Long Combination Wrench 348mm long.
Product Code:S30554
Toptul would be closest to these in length and better quality and same sort of price range .
