silkflex
Dave Maxwell
Kickapoo illinois
Can the silkflex be ground. I plan to use some and since it takes 7 days to cure. I am going to grind my floor one more time with a big grinder. It was done once and I have logged 120 plus hours with a 7 inch wheel getting what the big one didn't get. A lot of low spots. I have knocked the highs down now. When I grind I will need to epoxy right away. One more week of vacation left for the year and its getting cold.
NUTTSGT
Northern Central Ohio
Right on the tube Dave it says
Elastic seal
Never shrinks
Permanent bond
I'd probably take the advice from Legacy. One thing I'll suggest is that you mask off the joints when you use the Sikaflex. It'll make life alot easier when you try to make a clean finish.
D
Dave Maxwell
Kickapoo illinois
If it wasn't for such a wavy floor. I would be done already. Sweep a 7 inch grinder side to side and you feel the waves. Plus the ash dark spots
