I need to create and electrical panel for my milling machine. This will mount on the machine on the back or side and will supply power to dro, powerfeeds, light. I want to have a switch and was thinking that having a simple on and off selector switch mounted near the mill’s fwd/off/rev switch would make sense. I’d like the box to be small.
Holy **** is finding a simple switch not at all simple. You have pushbutton, rocker, cam, selector.
Has anyone sourced a simple 120v selector switch with an enclosure?
I found this switch and an enclosure
https://www.zoro.com/schneider-electric-non-illum-selector-swtch-22mm-2-pos-levr-zb5ad2/i/G2849357/
https://www.zoro.com/schneider-electric-pushbutton-enclosure-268-in-plastic-xald01h7/i/G1328826/
I am assuming for now that this is good for 120v and not a low volt switch. I will call Zoro on Monday.
This cam switch looks like it would work but can’t an enclosure for it.
https://www.zoro.com/advance-controls-rotary-cam-switch-600v-20a-2-pole-1phase-101470g/i/G2803561/
Another option is to drill a 22mm hole in the metal enclosure that will house the 120v outlets and just bend over or around the machine to turn on all the 120v goodies.
Any help is greatly appreciated. Thanks
