Simple wiring question...
katomike
NEC 300.3 says that all conductors of the same circuit, including grounding and bonding conductors shall be contained in the same raceway, cable, or trench. Is it okay to have 10-2 come out of the panel to a junction box then to another junction box with wiring for outlets coming out of each junction box? I have attached a diagram to hopefully make my question more understandable.
Thanks for your help!
pattenp
Virginia - USA
You diagram is okay. The intent of the code is for the hot, neutral and ground to remain together in the same cable or conduit. Another issue is for your 240V circuit is if it's greater than 20A then multiple outlets are not allowed by International Residential Building Code. 30A and greater are to be dedicated circuits to one outlet (receptacle). E3702.5 https://codes.iccsafe.org/public/document/code/553/9874212
K
katomike
The 240V circuit will be on a 30A outlet...so I guess that each outlet will need a dedicated circuit. Thanks for your help!!
K
katomike
Table saw. Also, if I run 10-2 from a 20A breaker can I use 12-2 out of a junction box to outlets?
Thanks!!
ddawg16
S. California
Thanks!!
Like Diesel said....why 10-2?
If you are 20A or less....just use the 12-2
If you think there is some chance you may go 30A later, then, yea, run 10-2.
Just remember, you can't daisy chain any 240Vac ckts over 20A. If you have 2 different 240 drops, each has to be it's own breaker and wires.
Personally, even if they were 20A or less, I'd still run separate ckts.
If OP is under the IBC...otherwise he can since NEC has no prohibition against doing so...
Hi,
How to series a circuit of 220 volt I want to see diagram
Did u mean daisy-chain? All AC outlets are wired parallel....
