Simplest way to handle multiple ground in junction vox
When multiple Romex wires go in and out of junction boxes what is the is essiest way to handle the ground wires?
I have been using a wire nut and pigtail when needed to sort this out. Is there a wire nut that can be used that could twist a few wires together and have one ground come out the tip of the wire nut? Is it acceptable to drill the tip out of a properly sized wire nut so that one ground could pass through?
I saw a copper looking crimp that solved this in one of my junction boxes. I assume this is readily available at Home Depot?
Thanks
Thanks
