Simpson-Mixing fasteners
bluedog225
Texas
I’ve been mixing 0.162 nails and Simpson strong drive fasteners on my Simpson hardware for a long while now.
My bad for not reading the instructions. Though sometimes a screw is possible where a nail is not.
I always assumed I’d get the best of both. Pull out protection and shear strength.
I’m certain that the Simpson engineers know more than me.
Does anyone know why mixing screws and nails is a bad idea?
It will take quite a while to go back and remediate. Since the nails are not coming out as a practical matter, I’d be replacing SD screws with nails.
jack stand
Lakes Region Maine
Personally, how do I not question that it's about selling more .50c - .75c+ screws? (Depending on the application)
I'm a big fan of Simpson structural screw after moving to them from GRK Rss series but after years of experience and involvement you develop a feel for the type and amount of fasteners necessary for the application. 👍
Fastening for inspection is a different animal, the inspectors hands are tied.
duneslider
Riverton, Utah
My guess is that they have not done testing on the infinite different combinations of screws/nails that you could come up with so they have no way of knowing what will happen and can't put a stamp of approval on it. I suspect that it is just fine though, but if this is stuff that is being inspected then you might be out of luck.
Either way, if you intend to fix it, I would call Simpson's tech line and ask them what you should do. Putting nails into holes that had screws may not be acceptable either. You might have to use a different size/length or something.
I really like their screws and just go that route when I am doing hangers (if I did a lot of hangers I would get a hanger nail gun and use nails though)
nadogail
Coronado, CA
If you follow the directions you can blame failure on poor directions.
If you decide that you know a better way you have assumed all the liability for connector failure.
Hank11
Tennessee
If you’re using either fastener as it is intended or required by code, you did it right.
bluedog225
Texas
No code. Just following the fastener specs.
My historical mistake was mixing screws and nails. Simpson flatly says “Don’t mix fastener types.” Wasn’t aware.
I was wondering if there was an engineering reason for this.
I’m putting in the last hanger for this project. Lots of holes to fill. I’d love to use screws but it specifies nails.
Driving 3.5” 16d nails into a some LVLs. 0.162". I’m bending nails every time.
Simpson allows me to predrill but no larger than 75% of the fastener diameter.
.75x0.162“ is 0.1215”
1/8” bit is 0.125”
argh!
mike93lx
Richmond, VA
1/8” bit is 0.125”
argh!
Palm nailers are pretty great and they're pretty cheap. I really like my ridgid
Too bad it's the last one, a metal connector nailer may have been worth it if the project had a bunch of these
duneslider
Riverton, Utah
It is critical that you do use only nails on hangers that say only nails, my understanding is the shear on the nails is better than the screws. On the hangers that allow nails or screws, I just can't see there being much of an issue mixing but again I am not simpson and don't know for sure. For small qty of hangers the screws are very nice to use.
rancherbill
Foothills County, Alberta, Canada
The short answer is that there is not a lot of engineering data on screws and their long term use. For example, does a screw hold as well 40 years from now if there is cracking and splitting in the wood. I have run into a very similar situation.
I know somebody will answer with the 'common sense" rationale, but, it is just the way it is. The proof is that Simpson wants it done a certain way and THEY ARE FAMILIAR WITH ALL THE RULES.
