Air_Cooled_Nut
Well, aside from "don't do it"
I already have a one 240V run for my air-compressor using two 20A breakers. My box has two spaces left which I would like to use as another 240V, 20A circuit (100A box). I would like to have a single run up the wall, across the ceiling, then split into a T, where one run would go to one wall and the other run would go to the opposite wall. Thus both outlets would share one breaker (well, two 20A breakers, technically).
Obviously I am not an electrician
but do try to do due diligence in researching what I'm doing plus I'm really good as a DIYer. So, my home shop is used by me only. I have nothing else (so far) that would require 240V but hope to get a 240V lift for the one side of the shop. If I should ever get a more powerful welder or whatever that requires 240V I would like the option to use it on either side of the shop. Naturally, only one of the two outlets would be in use at a time.
1. So, am I committing a cardinal sin by wanting to do this? Or is it okay? Or okay but just not recommended?
2. Also, is there some kind of indicator available that lets one know if a circuit is in use? Like a red light would come on if electricity was flowing in a circuit? That, at the least, would provide a warning.
The PO's brother had some contractor experience and did some of the work...without permits...
