justsam
My ballast fed 32W fluorescent t8 fixtures are beginning to have ballast failures. I have 10 fixtures and a total of 28 tubes. I really am not planning a replacement en masse as I am OK with the fluorescent but do not want to continue to invest in the fluorescent technology, be it tubes or ballasts.
So is there a winning wiring standard yet? Feed from one end or each end? I have no problem wiring the fixtures either way, and understand that a fixture wired for a singe end tube, that receives a double end tube will result in a short. I also understand the shunt issue in tombstones.
I just want to move toward a standard, if there is one, since I just had another ballast failure.
