rosshurlow1
I'm trying to finalize the HVAC plan for my 40x48x16 Barn, Just insulated with R50 in ceiling and R9 from blankets in the walls.
I really need help with the AC. originally I was going to pursue a 2.5 ton AC unit and air handler like this post
www.garagejournal.com
But the more I look at it I think maybe the Mini split route would be better. In summer I will mainly be using the left hand side of the barn and the right portion is just storage. So I'm not terribly concerned about uneven distribution. Intial thought for the unit is a 2 zone 24kbtu below. Any advice for pointers on the system?
The Heat will come from a radiant heat panel. Concrete is insulated as well and located in Indiana.
40x60 Red Barn Full HVAC Install
5 Ton Heat Pump, 20kw electric HVAC build thread. I am starting the HVAC build thread. Equipment is Ruud 5 Ton 14 SEER Heat Pump, Air Handler and 20kw heat strip with ducting. It's an ALL ELECTRIC SYSTEM. Big red Barn is a total of 60x70. 40x60x17 enclosed. I have started on the project and...
