Sizing a Wall Pack
sbosecker
Peachtree City, GA
Below is an elevation of the west wall of a building I'm planning. The width of the building is 46 feet. It's about 24 feet to the peak of the roof. The tallest garage door is 14 feet.
A concrete pad of about 40 feet will extend in front of the building. This wall will be about 120 feet from a residential street. There will be some trees between the street and the concrete pad.
I possible, I would like to light this area with a single Wall Pack mounted about 20 feet off the ground in the center of the building.
I do not intend to use a "dusk to dawn" system. I intend this light to be on a switch and to be used on an "as needed" basis. Since this will be "light on demand" it should not need to "warm up". If I turn the light on, I want light.
If the light is on I want it to be enough light to be able to see decently - especially up close to the building.
Does such an animal exist and, if so, how do I spec it & size it?
Scott
sbosecker
Peachtree City, GA
Sounds like something like one of these would work.
https://www.superbrightleds.com/ProductCompare/Product/5218/5217/5215
I'm sure there are many other types of LED wall packs that will fit the bill as well.. I just don't know how to calculate the lumens required though..
Beemer533,
I think there's a variety of possibilities but - like you - I haven't been able to determine how much light is needed to do what I want.
This building being in a residential - albeit low density - neighborhood, I want enough light but I want to avoid bothering the neighbors.
I've looked at some of the manufacturer's Wall Pack light "plots" and I don't know how to interpret them.
Best regards,
Scott
Best regards,
Scott
sbosecker
Peachtree City, GA
sbosecker
Peachtree City, GA
I've used RAB brand LED wallpacks on several projects recently and they worked out pretty well. https://www.rabweb.com/productLines.php?majorGroup=LPACK If you click on a specific model, there's a little 'EZ Layout' feature on the right side of the screen; click on that and you can play around with mounting height to see what kind of coverage you get.
OK... looked at it and...
Now I have to figure out how many foot-candles is appropriate for this situation.
Best regards,
Scott
sbosecker
Peachtree City, GA
Most places you have to shield lighting in residential areas. And this usually covers lighting in non residential areas that can shine into a residential area, as well as lighting in the residential area itself, that can disturb adjacent properties.
Example:
http://www.codepublishing.com/ca/chulavista/html/ChulaVista17/ChulaVista1728.html
bczygan,
If some of the Christmas displays I've seen around here are OK, I shouldn't have a problem. Ha!
Best regards,
Scott
