Sk 42470
Macduf
Seattle
I can't get the needle nose in to disassemble the ratchet, any advice? This one seems built different maybe older.
AceofSpad3s
I wish sk would just us snap rings instead of those laser guided eye seeking retainer rings. Does anyone know if you could just swap out the retainer rings with snap rings?
ganymede
New England
It's harder on your rat because it's an older specimen, probably late 30's early 40's. (Quite collectible!)
Snap ring pliers should work though.
defektes
Arizona
Two precision screwdrivers, pinch and lift with the other hand, IF snap ring pliers do not work. Wear safety glasses it will hurt your eye.
M
Macduf
Seattle
Stupid question , are these snap ring pliers. Bought them before looking. Really want to open this ratchet.
defektes
Arizona
I use that same set at work, has additional tips as stated, and will work fine for your ratchet.
XxToolAholicxX
SF **** Bay Northern California
I usually disassemble that ratchet with a small needle nose pliers....
I am a ToolAholic, Sometimes I regret it, Especially when the Toolman wont give me no credit
SMKS
USA, planet Earth
Another tip,
Take a mini pick and clean the grease and gunk out of the groove for the retaining ring. The groove is often filled with junk and that can stop the ring from compressing enough to remove the mechanism.
