Slab forms bracing
cansomike
Canso, Nova Scotia
I’m having a hard time driving stakes to brace my forms. Hard, rocky ground. I can’t even drive a wooden stake and was wondering if anyone has any alternate bracing techniques.
OccupantRJ
Eastern North Carolina
Angle steel cut to a point of about 20 degrees on one end. Drill holes to attach form boards. Mass produce them. I had to do this once in hard ground. Wood would just shatter, even oak.
850xpeps
Use rebar and fencing staples to the back of the form.
Or rent steel pins with nail holes that do the same thing.
Or make a L with the form and put gravel on the back of it.
Dureault_s
Drill in with a hammer drill 1/2 bit before pounding stake
strutaeng
Dallas, TX
This is what my form guy had me help him do when I built a 4' retaining wall in my back yard. The soil in one area was hard limestone. I had dig down with a demolition hammer to the footing.
machsnell
Northern Virginia
Hammer drill and get some concrete pins.
The ones with holes in them ar 5/8ths the smooth ones we use for form work need the 3/4" pins.
If forms are stiff you only need a few pins to support a 4 to 6 inch slab.
Sent from my SM-G960U using Tapatalk
