Slab question.
gasser
I am in the process of starting my garage project. I have an old unleveled slab and was planning on replacing it. Wanted to know if you can lay a new 4" slab over the old one. If I can, what is the options available.
Thanks, John
acer66
Western North Carolina
I'll tack along if you don't mind since I have a similar situation.
My two car garage has one bay with cracked concrete and the other has gravel.
My idea was to pour a five inch slap over it since it needs to be raised anyway.
mitusa
SW Oklahoma
Probably need more info. Do you have a garage with an unlevel slab inside or are you building a garage over an already existing slab?
G
gasser
Found the answer to my question already posted in the, of all things, the search box.
Thanks, John
mitusa
SW Oklahoma
Is your garage walls sitting on the concrete? Or is it a pole building with a concrete slab inside? I would suggest taking up the old slab and leveling all the gravel to grade. We usually use strings set at the height we want for the concrete and run a 2x4 or 2x6 under the strings leveling the gravel or sand until we reach a uniform depth. Concrete is pretty expensive. Are you planning on using rebar or concrete wire or fiberglass in the concrete? I would suggest a grid of rebar and making a footing around the outside edge of the pour....to keep water out from under the concrete.
HTH.
