Slab thickness for 4 post lift
69XR7
I’m looking at a Bendpak HD-7W four post lift. The specs say I need a minimum of 5” thick, 2500 psi
My garage floor is spec at 4” thick, 3500 psi
Will the higher psi compensate for the thinner slab or do I need to put in thicker concrete under the pads?
sammy7070
Auto Shop
That will work!
pbon
My bendpak hd9-xw manual says 3.5” at 3500 psi. Worst case, you could spread the load with 2x2 steel plate under the 1x1.
sz0k30
Hell, I've had a 9,000 lb 2 post lift on 4" for about 10 years now. Don't know the PSI of the concrete. No problems.
