Slide Hammers
ATC
VA
I did a quick search and didn't see much on this subject.
So tell me some of the good and bad brands, attachments, and such. I've had to rent one only a couple times in the past. The next time I need one, I think I'll just buy one, so I'd like to do my homework now rather than the day I need it :lol_hitti
Price is definately a factor. It is not a tool that will be used much at all. A couple times a year maybe. NO Snap-On or other overpriced brand please.
OTC seems to stand out initially with a quick Google search. How about KD, or Sunex?
sselander
CT
To make it more versatile, make sure it has an SAE thread on the emd. I believe it is 5/8-18. This way you can add different accessories.
The Harbor Freight one is metric, which limits the attachments you can put on.
There are knockoff brands with a standard thread, you just have to look at the specs.
A
ATC
VA
Not a popular topic I see. Thanks for the info. I'll check into the OTC's and a few attachments
HTGTS350
Ive got a no name one, 5/8 UNF thread and I usually make my own attachments for it.
f66
I have a KD and Kent Moore 2619-1. I bought the KM from ebay. It has the 5/8 - 18 threads mentioned earlier. One other factor to consider is the weight of the slide. The KM I have is heavier than the KD. Frank
crewchief888
NW indiana
i have 2 or 3 OTC slide hammers
most of my pullers and attachments are also OTC, i also used to make a lot of attachments as i needed them.
:beer:
greasemonkey44
memphis
i have a HF..... needed it when i was in a bind
replaced it with an OTC Silver *******; damn nice
there is also a snap on rear bearing slide hammer around here too
wannab20hatch
Gainesville, Ga
I have a tool aid and the attachments are cheap quality just bend not really help. I got a snap on one last month when they were on sale. I love it so far. Really stout and the attachments are strong.
jmm
NC
I almost got one not long ago, ended up borrowing a nice Proto model.
Did a little research and ended up thinking KD was the best bet for me. Doubt it's as nice as my buddy's Proto, but it's an inexpensive kit that covers the bases from a brand I'll trust. I'm not positive, but Mac's slide hammer looks to be the KD re-branded.
One of these days I'm going to get one of my own; if you think about it report back with what you got and how you like it.
Red_Bull
Columbia, MO
i have an old school otc that came in a blue metal case...use it more then i ever thought i would and its never let me down
NUTTSGT
Northern Central Ohio
I've kept an eye out for one when at the swap meets and haven't come across one yet. I guess once guys buy one, it stays in the tool box for life.
jmm
NC
That'd be my luck...find myself in situations where one would work better than regular pullers fairly often. Get one and those instances mysteriously disappear.
I've found two at flea markets and such, but they've not been in great shape and both lacked accessories. Oddball tools like this are hard to find second hand at pawn shops, flea markets et al.
EdJack
I bought one at Napa autoparts. It looks like either a re-badged OTC Silver ******* or a high quality knock off of an OTC Silver *******. It came in a case with a bunch of attachments.
The key is whatever one you buy, get one with the industry standard 5/8-18 threads. That way, you can put all kinds of attachments on it.
My favorite attachment is the inner CV axle puller. That makes pulling CV axles a piece of cake. Another nice attachment is the one that you install the threaded end of a pair of Vise Grips. Then clamp the Vise Grips on the work piece, and start hammering.
andrew9
This is the one I use
I didn't make it, I've always wanted to make it prettier, but it works very well.
It has a bit of angle welded on the end with a hole in it, you just put a bolt or a stud through and put a washer and nut on, makes different threads and fittings easy
Its 19mm (3/4") bar with a nut welded on the end, 600mm long (2ft) and the weight of the hammer part it about 3kg (6lbs+-)
Here in Australia, I've never seen a slide hammer that was not built in the workshop.
Steve_P
OTC is about all that's affordable and decent quality, so that's mostly what I have. I have a large kit with 5/8-18 thread and a smaller setup with 1/2-20 threads. I think it's all made in Taiwan. just go to tooltopia and search for slide hammer or OTC slide hammer
37ford4dr
Arlington Va
i have the two.....the best one came from eastwood that came with their stud welder kit and it is a very nice....makes my cheapie one look like a toy
devoncoolman
quakertown pa
if your a professional tech snap on is the way to go. the pullers are interchangeable with the slide hammer. the slide hammer is super heavy duty and the screw is thick and will last forever. I bought two used ones one is from the 50's and one from the late 70's they still look new and perform great! For occasional use and home use the otc silver ******* is great its cheap and the whole kit comes with a bunch of adapters.
