Slip Joint Pliers - You uses
mobiledynamics
Gotham City
Just doing some spring cleanup....
Just used this the other day on a very small metal barb fitting - removing the plastic sleeve off of the tube that was connected to it.
Can't think of the last time I used this before them.
Curious is this a useful tool in your toolbox or not...
64merc
Texas
I sold/gave away most of mine. I might use one maybe once every few years. IMO, there are better options.
Tunger
I have an old pair of fleet brand slip-joints, use them everyday at work for various things.
iroc409
What do you use instead of slip joint pliers?
I use them to grab things, to hold things, to grab things and pull until the slip off and smack me in the nose, to get those factory spring-type hose clamps off things, etc.
Bruce Lancaster
They are like vise grips and adjustable wrenches...good for minimalist tool kits, good when you don't have the perfect tool for the job.
ajchien
Los Angeles, stuck on the 60 freeway.
They're a substitute for my fingers when I need a bit more torque, or if something is a little too unpleasant to handle. Like undoing stuck garden hose connections, stuck stopcocks, turning nuts and bolts when you dont mind marring them up. Similar uses to a really small pipe wrench or small channellocks... I guess I kinda use them like a pair of pliers... :p
Matt018
Many uses working on small engines, I use the wider section to break hoses loose, and then for hose clamps as well, along with many other odds and ends, I only have one pair though, You dont need too many sets, they are just good to have.
countryroad82
Kentucky
I use them to round off bolts for people I hate...... Oh wait that is what happens to me when someone else uses them!! Mine sit in the box more than anything I have very few uses for them other than a few already mentioned.
Mostly to hold small parts when wire wheeling. Sometimes to squeeze something into place. Never for a fastener...
rebelram
AL
Slip joint pliers is that one tool everybody has along with the other tool, a hammer. I rarely use slip joint pliers, but I have them in a couple of my tool boxes. If I didn't have any I'm not sure I would buy some, but I'm not about to get rid of the ones I have. As to what I do use more often, it's usually Channelocks, Linesman pliers, or needlenose. I also have a pair of Knipex combination pliers I have been using a lot more lately.
House Sparrow
Lewistown, PA
They have their uses, but also have their limits. I like them for twisting loose stuck vacuum lines and fuel lines. They're ideal for small squeeze-type clamps. They're also handy for pulling off those stupid rubber inserts that always get stuck on GM brake caliper bolts.
One thing I never do is try to use slip-joints as a "wrench substitute". A rounded bolt/nut and a blood blister do not add any fun to a job. I do love my Snap-On Vacuum Grip slip-joints, wish they still made 'em.
