Slip roller ?
FANTM58
Brighton, Co
Ok guys I won this on an online auction.
It’s a 9” slip roller. I’m trying to find some info on this unit.
There’s no ID tag anywhere on it. All my searches only finds
Ones with 1 crank handle. This unit has 2
Each controlling a different roller.
Anyone out there seen or used one of these.
I won it for $29.00 ..
Thanks
Robert H
Dustball
Hudson, WI
Let's start with the fasteners- are they metric or SAE? That'll potentially help narrow it down to if it's US or international.
Dumber than lumber
It looks like a cute little goober. For $29 it would be fun.
Sounds like you didn’t realize what you were buying.
F
FANTM58
Brighton, Co
I k we it was a sheet metal
Roller, I’m just a bit stumped at the dual cranks
Each one connected to a different roller.
But I’ll mess with it. And figure it out..
metlmunchr
Normally, the 2 infeed rolls (the ones stacked vertically) are geared together to turn in opposite directions such that they feed the metal in while the third roll freewheels and does the actual forming.
Cranking a single roll would require the infeed rolls be adjusted tight enough that the other roll is driven by friction. The problem with that is the sheet will feed perpendicular to the point of tangency between the upper and lower rolls and essentially just **** into the third roll. Depending on the adjusted position of the third roll, the sheet may climb the third roll and begin to form, or it may just stop.
With both rolls driven, or cranked in the case of the OP, friction drives the sheet from both top and bottom sides, and the rolls can be adjusted more loosely. When the sheet contacts the third roll, the looser clearance between the upper and lower rolls allows the sheet to more easily deflect and begin to climb the third roll. As this happens, the sheet is pushed more tightly against both infeed rolls this increasing the available friction for driving the sheet.
As is, cranking one handle would likely be adequate for rolling light material like 24 or 26 ga, but rolling something like 16 or 18 ga probably require cranking both handles. Not an ideal setup as the handles have to be cranked in opposite directions. Adding a set of gears to the infeed rolls would make the device multiple times more useful for one man operation.
F
FANTM58
Brighton, Co
Good information, thanks
csp
Franktown, CO
I saw that auction and thought about bidding on it, but I didn't win the items I was really after and the 9" capacity wasn't very appealing. I wondered as well why it has two handles.
That auction had a small lathe and an Atlas shaper in it, so it's very possible that it was shop built.
F
FANTM58
Brighton, Co
When I went to pick it up. It was in a small shed out back. I have no idea how they were going to get that old large Bridgeport mill out of there . They must have built the shop around that thing..
