Sloppy Universal Fixes
Zewnten
Tired of my 1/4 sockets always flopping around on a long extensions, I found one by USAG PT# U02410301, that is adjustable tension that interests me, but I can only find it over seas so fair amount of shipping, $26.
What is your home brew solution? I've tried o-rings but none hold tight enough and I don't care for the electrical tape solution. Or if someone has a place to order the USAG I'll go that route
Wamsutta
Amarillo, Texas
I've got a Williams M-140A.
It's buttery smooth and turns almost at a full 90.
ChrisLS8
Most brands will be riveted so loosening will be inevitable. I'm wondering if there are any brands out there that use Torx or Allen heads instead much like a flex ratchet
TwoInch
NW INDIANA
I much prefer a looser universal so I can adjust it with tape. Done it so long I have no issue with it.
I actually have a number of each drive, and have some clean, and some with varying degrees of stiffness ready to go lol.
Sent from my LGLS676 using Tapatalk
Skin
Boston
Koken and Napa Carlyle both have a screw to tension. Hazet does too but they only make 3/8" universals.
454ragtop
Carver, MA
I've got an old 1/2" drive that I put a piece of heater hose over, works pretty good. I've thought about, but haven't actually tried, using shrink tube to stiffen up u-joints.
bimmer630
Tape is messy
I slide an o-ring over mine when they flop too much. Granted the o ring will get cut and fall off eventually, but most of us have a collection of old o rings laying around anyway
