Small Torx Sockets
ultgar
New Jersey
Can anyone tell me what applications require small E-torx sockets (ie, E4, E5, E6 and E7)? I stock E5 and E7 sockets (in Facom) so people don't have to buy whole sets...not sure about the other 2 small sizes.
E4.......??
E5 - for Volvo ABS modules
E6.......??
E7 - for BMW E46 (3-series) window adjustments and BMW N63 (V8 engine) vacuum pumps
Anything else for E5 and E7?
SD
gigamel
E7 - Inlet manifold studs GM Ecotec
Looking at my E4, E5, E6 sockets I don't think I ever used them. :)
Carquest
South Carolina
I believe the E-5 removes the distributor cap screws on a Chevrolet LS1 engine. Not sure that is very helpful for your customer base though.
ptgarcia
Alta Loma, CA
I have a 1/4" drive Tekton ratchet that uses the smallest torx bit I've seen to disassemble the head. Looks about 1/2 the size of a T-10.
nbpt100
Massachusetts
Never seen the realy small ones or I should say I never needed to use a realy small one.
Have used mid sized ones on Dodge and Chysler upper strut mounts.
Sam'sAutoParts
Northeast PA
I know the tilt columns in pre-air bag trucks and cars used a e torx, but I can't think what the size is off the top of my head, I wanna say it's a E6. There is 3 screws and when they loosen up the Column gets real sloppy, pretty common problem.
shockwave
Marietta,ga
E5 and e6 studs on back valve cover for retaining harness on older 3.0 and 3.3l
Mercedes use multiple e6 e8 and e10
md21722
Mt Juliet, TN
I had a wood chipper that used E4 or E5 on carb studs. My buddy laughed at that and put a set of vice grips on them.
