Hair dryers still are, that's why AFCII know when they first came out the shop vacuum was excellent at tripping them.
IIRC kobalt vac and GE breaker.
It's a myth that code requires a refrigerator/freezer to be on a GFCI. The code says GFCI is required in kitchens "where the receptacles are installed to serve the countertop surfaces".I would NEVER plug a refrigerator/freezer into a GFCI ! The risk of loosing the contents is just too high !
Best practice is to put a refrigerator/freezer on a dedicated circuit (less chance of trip) on a non-GFCI receptacle in the refrigerator/freezer bay.
I've got a GFCI outlet in the garage that thunder will trip.....Been in the house since 2008 and changed it several times and it still does it.But all of my garage/basement outlets need to be GFCI.
Lots of people have garage fridges
I had run new kitchen circuits and a few in the basement, but hadn't replaced the panel yet. Welded something quick using a 120v outlet downstairs, it tripped the kitchen GFCI and fried the coffee grinder and a fan.I've got a GFCI outlet in the garage that thunder will trip.....Been in the house since 2008 and changed it several times and it still does it.
How many 240VAC appliances (that use 120VAC internally) use only 3 wires ? Show me one documented case where either these have cause fire/injury.
If a fridge has nothing but beer/sodas, I guess a GFCI is fine, but personally, I won't plug something that holds food into a GFCI, regardless of code.But all of my garage/basement outlets need to be GFCI.
Good point. I have one as well. It's for beer mostly. I also have a big freezer in my pantry which is not a GFCI.But all of my garage/basement outlets need to be GFCI.
If the receptacle is within 6' of the sink, the refrigerator is required to be protected by a GFCI. Kind of stupid since 1) it's behind the fridge, and, 2) the receptacle could be 6'1" away and the side of the fridge could be 4' or less from the sink and not need the GFCI.It's a myth that code requires a refrigerator/freezer to be on a GFCI. The code says GFCI is required in kitchens "where the receptacles are installed to serve the countertop surfaces".
Damn it. And now here I am headed to the garage to examine that circuit... it's a freezer full of meat and frozen items.I've got a GFCI outlet in the garage that thunder will trip.....Been in the house since 2008 and changed it several times and it still does it.
Rip that damn gfci out and install a regular receptacleDamn it. And now here I am headed to the garage to examine that circuit... it's a freezer full of meat and frozen items.
Wish I could, but it feeds the outside receptacle by the kitchen door. Wiring in this house is strange....The GFCI for the kitchen sink outlets also feed the outside one by the front door. The one for the small bathroom feeds the one inside by the kitchen door....Rip that damn gfci out and install a regular receptacle
You can't put the gfci outside?Wish I could, but it feeds the outside receptacle by the kitchen door. Wiring in this house is strange....The GFCI for the kitchen sink outlets also feed the outside one by the front door. The one for the small bathroom feeds the one inside by the kitchen door....![]()
GFCI required when the receptacle is above a concrete floors (basement, garage, etc).It's a myth that code requires a refrigerator/freezer to be on a GFCI. The code says GFCI is required in kitchens "where the receptacles are installed to serve the countertop surfaces".
This.Rip that damn gfci out and install a regular receptacle
If it is just a straight feed from the protected side of the GFCI receptacle, some simple rewiring in the junction box will fix it.Wish I could, but it feeds the outside receptacle by the kitchen door.
Google says that is likely STATIC electricity !If you search for people getting shocked by clothes dryers that do not have a dedicated ground you'll see plenty.
Shocking.The other place they are really good for is the dump.
Slab houses don't need GFCI everywhere and everyplace has a concrete floor.GFCI required when the receptacle is above a concrete floors (basement, garage, etc).
Whiz: It would require tearing out numerous walls to rewire this place. Nothing was run thru the attic, with the exception of lights up there and fixtures that penetrated the ceiling. All of the wiring was run thru the walls. Goofy freakin house was designed by a bachelor that no interest in having access to the back yard. Two doors on the house exterior and both are in the front of the house.....If it is just a straight feed from the protected side of the GFCI receptacle, some simple rewiring in the junction box will fix it.
not sure why you can't remove the gfci inside & relocate it outside. then your outside receptacle is gfciIt would require tearing out numerous walls to rewire this place.
Says where in the NEC? By that thought most of the tract homes built should be GFCI's for all receptacles since they have concrete floor throughout the dwelling.GFCI required when the receptacle is above a concrete floors (basement, garage, etc).
What a gig for the sparky. Sell a bunch of expensive breakers, get paid to swap them back out and the use those same breakers at the next house. Get paid to swap them again. A afci inspection service.AFCI's are really good for installing into a new construction home until the final inspection and then replaced with regular or gfci breakers where applicable.
The AFCI will only trip on a series arc if it senses a 5A sustained arc.If you watch closely the arc fault breaker it only tripped when there was a sustained arc. Scary.
Either the GFCI was bad or your appliance was bad. should've investigated this especially with a washing machine where there is very real potential for a short to ground/leakage current that could harm someone.However, there are still too many false trips (son has an old washing machine; tripped mid cycle 3 out of 5 times; swapped in a normal receptacle).
its also written by electricians that...The NEC is written by people who are "in the industry", which means they are EMPLOYEED by one of the major electrical suppliers.
a single bond as in neutral bond or metallic pipe bond? well if they didnt have a single bond ie the neutral bond, then breakers wont trip when there is a line or ground fault. I highly doubt there are very many houses without a single bond.Segue - How many MILLIONS of homes in the US still do NOT have a single bond on their electrical system AND a ground rod ? How many 240VAC appliances (that use 120VAC internally) use only 3 wires ? Show me one documented case where either these have cause fire/injury. If fire/injury was common, you can bet the residential insurance companies would charge a premium for homes that do not comply with the current NEC !
if the fridge or freezer is in a room or location where GFCIs are required, installing a single receptacle on a dedicated circuit will not exempt from that code requirement.It's a myth that code requires a refrigerator/freezer to be on a GFCI. The code says GFCI is required in kitchens "where the receptacles are installed to serve the countertop surfaces".
