Snap on 8mm wrench soft?
90zcar
Going thru a couple things in my tool box and I noticed my snap on 8mm fd* wrench has 2 divets in the end. Is this ok or should I warranty it out?
sberry
Brethren, Michigan
One of the only wrenches I own that has a spread jaw is a Snap, don't really care as the only use for it is the occasional box end job.
splicer64
GA
The only time I've seen that is when someone "Double Wrenches" as said earlier though common and very functional it almost always causes chrome to chip...if your dissatisfied by all means warranty it through your dealer or over the phone.
ttpete
Dearborn, MI
That's a tiny wrench. It looks like it's been abused at some point. Any fastener that would be turned with that wrench would twist off before the wrench was harmed.
90zcar
I bet that wrench is not even 6 months old. I have no clue what it came from but why would I be "double wrenching" with an 8mm
Skin
Boston
Its been, what I call, "side loaded". Someone had the thing barely catching the edge of a fastener then tried to turn it. That's the resulting damage when the fastener is only caught in the very ends of the wrench. Likewise its a good way to mar nuts and bolts and round corners. Any brand will do that, has nothing to do with the steel.
Trucky
This. Done it a few times myself. Literally any wrench will do this. It's way too much stress for the edges to take.
augustus
Columbus, OH
I had to double wrench two of my friend's snap on wrenches (per his direction) and they were fine, it was only a tension pulley, but after reading some of these comments, I'm not sure i'd do it again.
90zcar
This is what I think most likely happened.
Because I know I never double end wrenches together and I always use my battery wrench on batteries.
Now I gotta decide if I wanna warranty it or not with my dealer. I don't want to seem like a pain in the *** because it is kinda a petty issue I guess
90zcar
Just an update....I decided to take it on the snap on truck yesterday and I told my dealer I don't know what happened but I wanted to see if he seen it before
He told me it probably wasn't on the fastener the whole way. He said "no big deal that's definetely a warranty issue" and handed me a new wrench like that.
I told him I never doubled up the wrench. He then proceeded to tell me that it doesn't matter if I doubled it up. Snap on doesn't say anywhere that you can't double up wrenches! Told me these are the best wrenches money can buy and to use them however I need to and if I have an issue come see him
That sure made me feel good. Also made me more willing to spend more money with him which is his main purpose
ADSR
Glad it worked out for you. I don't think snap on would let you use them as a slug wrench tho.:scared:
DodgeMech
i do double wrenching daily on the alignment rack...my williams supercombo 15/16 attached to my no name china 1 1/16 cranking on dodge 1 ton 4x4 control arm bolts
ChevyEFI
Phoenix, AZ
I did that to a Craftsman raised panel this week.
Definitely doubling up.
That's lucky your dealer took care of you after someone else did that to your wrench.
90zcar
Nobody else did that to my wrench except me. Came to the conclusion I was cranking on something n barely had it on the nut
ClineWrench
You know whAts funny: I just realized that I bought my flank drive plus wrenches when they first came out. So long ago that there were no FDP below 10mm.
Looks like I need to update my 8mm & 9mm.
90zcar
Don't forget 7mm!! I'd buy that before I'd get a 9
ClineWrench
Funny you should say that 90zcar. I have come across exactly one 9mm nut and one 7mm nut in my entire life (to my recollection). So neither have a serious need to be replaced. The 8mm however i use darn near everytime i so much as look at a car.
So in order to keep my set complete, I need to replace the 8 and 9mm. But now that you bring it up, I have come across a few 6mm bolts and nuts. So naturally, if theres a FDP 6mm, I'll need to buy the 7 along with it.
90zcar
7mm was used in a lot of 80's early 90s gm cars. Almost everything in the dashes and interior was a 7mm head. I have a snap on 7mm wrench but that isn't a fd+. Anything that is 7mm usually comes out by just blowing on it haha
