Snap on hard handles, what would you put them on?
RobertMo1988
OK so I looked for so long everyday and every night for some of these handles. And recently some popped up about a month ago, I bought every one he had (which was only 4, $12 each) so I have 4 handles to make either ratchets or whatever i can. I am limited to what i can make since the handles are the same size as a sdd2 or a standard 3/8'' drive ratchet handle. So what would you guys make with them? 3 are the normal hard handles, one of the 3 has a dale earnhardt signature on it. The dale earnhardt is slightly smaller in squareness than the other two of the same style.And the 4th handle is a contour hard handle. i think contour is what they were called.
i was thinking on the newer handles
12"- 3/8 breaker bar.
a FH80
a THL72 (dale earnhardt)
but what would you put the older handle on?
or what would you suggest putting these on?
I have an older LSF720 1/2'' drive in 3/8'' that could clean up real nice with a new handle, it has a contour handle on it.
canuckian
East coast of Canaaada
i'm putting one on the snow blower that's mounted to my tractor. the handle that controls the direction of the chute split in 2 so I'm going to drill a green one (JD tractor) out to put on it
I also put one on a 24 inch comfort handle breaker bar and will be putting on on a SHLF80 when I find one big enough. putting a yellow one on an FHNF100 as well.
