snap on krl side locker help!!!!
citroen_grant
aberdeen scotland
Hello, i have a snap 7022 with a hutch and im looking to get a sidelocker, i was wondering if i could get a inside to what it takes to install etc, if anyone who reads this that owns a krl locker it would be awesome if i could get your input,a couple of questions i have are fitment issue, i have the 7022 and its 30 deep, do you get a locker that goes that deep also i was reading the krl manual and it mentioning about drilling holes, i would of thought it would be direct fit onto the box and bolt into the handle holes......it would be awesome for anyones help
thanks citroen grant
chadster1
Terrell, Texas
The lockers have a lip that hangs on the edge of the toolbox. There should be holes that line up the with holes for the handle on the box.
colin39
Yep this ^^^^^^^^^^hung mine a few months ago
And fitted it with a power socket with usb charger points
C
citroen_grant
aberdeen scotland
grant.sim.58
, that's my box
colin39
No sorry its mine
And now its hidden sorry.
It hung on the lip and bolted straight through the bolt holes for the handle ,that were already in the locker
redwrench60
East Tennessee
I have two KRL side lockers and as stated they have a reinforced lip that hangs on the top edge of the roll cab. The locker then has two holes in the inside that line up with the reinforced holes that the roll cab handle mounts in, bolts are included with the locker. Lastly, they recommend that the user drill two small pilot holes in through the very bottom lip of the locker and through the bottom lip of the roll cab for two more self tapping screws (included) for extra security. There's dimples in the steel bottom lip noting the drill locations.
Hayzuse
Has anyone here put epiq lockers on a master 3 bay?
moto440rider
I have had them next to my master series double bank. But never bolted them on to the box. Problay could with out much work but never wanted to drill anything.
Chad
xurusaibobx
i have a 1023 with hutch and both lockers.
i used a small jack under the pallet it comes on to jack it up to the same height as the roll cab and the slide it onto the lip of the roll cab with the lip on the locker.
the locker always come with door opens to to the right. its universal for left side and right side option unlike the Epiq series where there are 2 different lockers for left and right side. the KRL series if you want to put the locker on the left hand side then you have to unscrew the self tapping screws that hold the hinges in and flip the door upside down. removed the magnets and switch it to the other side of the locker. it ***** to do this because you pay so much money for a locker that should come ready to install and not have to redo the dam thing in the first place.
also with the hardware kit comes with 2 plastic washers that you put on the bottom of the locker between the locker and cab it pushing the bottom of the locker out a bit so the top end sits more flush with the hutch or top chest.
C
citroen_grant
aberdeen scotland
great so there is no drilling involved like what its says in the manual, also I have the 7022 with the hutch and its 30 inch deep can you get a locker to match the depth??
fishsalt69@
thanks for the help bud, I was reading the manual you get with the box and it was going on about drilling holes
If you want to connect the locker to the top box or put it on the side of the box without the holes for the handle you need to drill some holes.
It just depends on if you want to move the box and setup preferences.
Use a swedge nut in the hole you drill in the box so you don't have to have a nut on the box side.
