Snap-On seal remover pick set?
90zcar
Wanted to get an opinion from anybody with these if they use all 4 in the set or if there's a more specific one that you end up using and the others just sit
The set is SGSR104AR and runs about 45 bux for the set or 11 individually
wrenched87
Waterford MI
A buddy of mine convinced me and I think there great. There like pick tools but you don't have the concern of piercing through rubber. You will find many other uses I'm sure. I did. I definitely use the bent ones more but they all come in handy for me.
thinman
Kansas City, MO
Bought the short, straight one. Use it for all kinds of things besides O-rings. Definitely want the rest of the set. Very handy.
90zcar
Wow quick responses! Sounds like you guys like em. I myself was thinking the short ones would probably be used more. Who knows I'll probably get the whole set but I just wanted to see if I got any responses like "I only use the short blade curved one"
xj31
I have even used them on plastic trim parts. They don't damage stuff like a pocket screwdriver
turdferguson13
fatfillup
Finksburg, Md
I bought the set after my using my mechanics set. We work on pressure washers and they are quite handy for doing seals with damage. Wish I would have know about the Mayhew before buying the Snappy's though (kick self smiley)
Note, I go to a lot of auctions and have only seen 2 sets in 5 years.
redwrench60
East Tennessee
I'll be the dissenting opinion. Bought the set several years ago thinking I'd use them constantly because I do a lot of o ring and lip seal work. I found it hard to dig out tight fitting o rings with them not to mention the rubber soft grips become slick as goose **** when soaked in oil, ATF, hydraulic fluid ect.
Also the blades are rounded to prevend damage to the seal but are thick enough to damage the o ring groove on the part while digging out some seals.
I don't ever have any trouble with damaging seals and o rings with my pick assortment. They'll dig out any o ring or lip seal, even hardened ones.
I traded my set back on the Snap-On truck. Haven't even once thought, man I wish I still had those seal tools.
WJD
Rocky Mountains
I would rather use my old five piece pointy snap-on set also. They have served me fine for years on installing or removing seals/0-rings on a variety of things.... Well enough I have not looked for different ideas:D
basspro
In the sticks, WI
Ive thought about buying that set, but ive just made a few of my own out of cheap screw drivers, Ive made them to look pretty similar. My picks have all worked well for me for the most part, so I never did buy the seal tools.
sparky5982
Is there a warranty on the Mayhew set? Also COO on the Snap-On set is easily found to be USA. I couldn't find COO for the Mayhews.
Great question. Here is their warranty/info page. It gives a brief history of their US manufacturing bona fides and states their manufacturing facility is located in Massachusetts. I didn't see anything stating that all tools are 100% US made though. Their warranty looks like the standard lifetime for workmanship/abuse not covered type.
