Snap ring (circlip) plier recommendations please
Brunel
Hi, I am sick of not having the right snap-ring (circlip) pliers and want to buy a set. Any recommendations? I am in the UK.
I was thinking of one of the Knipex sets of 8 (how much difference between the two types is there?).
Any alternatives? Or should I go for an interchangeable tip set?
Thanks!
terrific
The two sets that always get recommended are Lang 3595 or Imperial IR-6CK.
Steve_P
I have the Knipex with the piano wire tips; they're really nice, but pricey. I appreciate the quality every time I use them.
If you don't want to go for that, then the Lang 3495 set is a bargain.
oldschoolcraft
Bay Area, California
I have the knipex "precision tips"
I just inventoried them, here's the ones I have:
48 21 j21
48 21 j31
48 21 j01
49 21 a21
49 11 a1
49 11 a0
49 11 a3
49 21 a11
48 11 j0
48 11 j1
49 21 a31
49 11 a2
48 11 j2
49 21 a01
48 21 j11
48 11 j3
paulsomlo
Northern Colorado
Knipex with the forged tips - they afford a little better access than the "precision" tips. And no, don't waste your time on interchangeable tips. You might also look at the Gedore set, a bit less money.
Brunel
Thanks, I wasn't aware of those. Imperial appears to be an Australian American company with no distribution in the UK, but the Lang set is available over here at a reasonable price. EDIT: COO fixed but they're still unavailable this side of the pond.
Brunel
Knipex. Pay once cry once.
I've already done plenty of crying as I have about 24 pairs of Knipex pliers and cutters. But I have no regrets as the quality is first rate. I actually think their pricing is very reasonable. Some of my Knipex tools have taken a pounding on industrial electrics, and they're holding up really well.
FigN⋅m
One of the very few Snap On tools I acquired is the 90* version of the linked Imperial type of pliers.
The cam lock thing that converts them is a joy to use and I would gladly source the other versions.
I can't speak for the metallurgy of other mfrs., (they're probably all made in the same factory)
but they're definitely a recommended style to shoot for.
timgunn1962
Lancashire, England
I've had good results with the BGS circlip pliers in a general industrial maintenance role. I bought them a couple or three years back to get coverage of a good range of sizes at reasonable cost, fully expecting to need to replace the couple of pairs I use the most with better ones (Knipex or, my preference, Facom). That's not happened yet as the BGS are holding up well.
Brunel
(snip)
I make that 16 !!
There's only 20 in the range - 5 (sizes) x 2 (straight / bent) x 2 (int / ext)
I think you need to get the last four to complete your set :)
Steve_P
Do you have any data to back this up? I have the Knipex piano wire tips and the portion next to the tip is only a few thousandths of an inch larger than the one-piece Imperial/stride that I have - as shown above. Yes, bigger is bigger, but even .010" is well within manufacturing tolerances alone.
paulsomlo
Northern Colorado
Personally? No - I'm going off two posts that I've seen on GJ in the past.
oldschoolcraft
I went with the precision tips when I bought mine a few years ago. I dont remember why, I tend to always buy the most expensive and best tool because then I can never regret it later. I came across a video recently on YouTube where someone was interviewing a Knipex employee in a Knipex company store about different pliers and briefly the snap ring pliers came up and the Knipex dude said the precision ones were better. I got the impress forged were cheaper. They stamp the metal down of the entire tip into the shape. Whereas precision, they drill a hole in the pliers and then install the tips. Since the tips are made separately, there's more precision to them.
lardy1
I've been happy with Lang but have never used the forged type. They have always sounded great to me but the Langs have never failed and I'm not a pro wrench or regular user of them.
KnurledNut
n/a
I find having a variety of sizes and angles tips more important than brand. I have a hodgepodge of quality brands and sometimes one handle style is more ergonomic, or the design allows better access, or the tips engage better than another brand.
If I had to be pinned down to one brand/set, I would likely choose between Snap-on, VBW (w/ bare metal textured handles) or Knipex. Facom/MAC/USAG with the precision tips have always intrigued me but never have used them. The closest design I have to them is a pair of turkish-brand Retta’s.
Steve_P
Yeah, I've read those same posts and challenged them with that same fact. And no data was provided to prove it. So.... I personally don't repeat stuff that others say. YMMV
AEAdam
SE PA
I am not a fan of KNIPEX generally, but I love their snap ring pliers. The forged models are SO much easier to use than the sheet metal ones I used to have. +1000, don’t buy interchangeable tip models. I bought the 6 pc “master set” and just added 2 smaller tipped models.
PBCampbell
WV
I've had the Knipex "precision" tips since they came out I think. I started with the 8-piece set and added the "0 and 3" sizes. I think the biggest benefit for these would be the "wear" resistance for heavy use. I will say they were a big step up from the Lang/Imperial pieces that I had at the time and were very well used, maybe a bit worn out, plus ones that were missing or just abused to the point of useless. I had my hands on a lot of retaining rings back then and the Knipex were not terribly expensive. I'd say less than $200 for the 16 pieces. A DIY/home shop person would be well served by the Lang/Imperial set and also there are a lot of other options now for forged retaining ring pliers which did not exist back then.
paulsomlo
Northern Colorado
Blind1
I bought the ICON set. They worked infinitely better than the reversible pair I had.
pizza
Midwest, USA
The two sets that always get recommended are Lang 3595 or Imperial IR-6CK knipex precision and gedore
ftfy
shakenfake
Shlumpt, TX
@paulsomlo Wow of course right when I don't need them anymore! I needed a pair of externals like 2 weeks ago.
I did go with Knipex forged tips and they are excellent. My Channel Locks and Proto have been resigned to the back of the drawer.
bobg03
conway sc
I'm not a big Harbor Freight fan, but I just got an email that the 8 piece Icon snap ring pliers set is $29.99, Tuesday May 21 only, apparently a one day deal.
Same here, for my limited use the interchangable ones are fine, but if I wanted a dedicated set and wasn't making a living with them that Icon deal is great. I have a set of Icon box wrenches and one of their pliers models. Decent tools for the non professional.
swsman
Earthbound
Picked up the Icon set just earlier.
For $30 and my limited use I think they will do just fine.
I did open the case and checked them out for defects prior to paying at the register.
For years I got by using stamped interchangeable tip ones from OEM tools.
darkzero
SoCal
Back of the box shows off that they are drop forged carbon steel, not even Cr-V. Big pass
That explains the poor reviews on HF's site & elsewhere. I was looking to buy them because of the great deal but decided not to after hearing the tips break off & have size/fitment issues.
disston
Silver Spring, Md
I have more than a dozen pairs of circlip pliers. Was doing transmissions for awhile and aquired all of these. Many other things in our lives need a special sort of plier. Well some of them are beat up and I have modified them. Sometimes the one that works is the most beat up one.
I have a set of 4 pliers made by Blue Point and sold on the Snap On trucks. Think I have only had to use one of these pliers. Not sure anymore, don't do much of this work anymore.
engineer2
Chicago burbs
HF just had a sale on their Icon 8 piece set. $75 down to $30, one day only. I stopped at the local store and they said there were 15 people waiting out front at opening time to buy the 9 sets they had. I ordered a set online.
