Snap ring for SK 45170 ratchet?
rjvjeepster
I was just lubing up the ratchet and then went to put the snap ring back on, heard a ping and the snap ring is forever lost. :lol:
What size snap ring do I need? Thanks!!
plinker
Northern Wi
They're not really a standard snap-ring, I likely have a good used one laying around if you want it.
zktk01
KY
Of all my ratchets I have taken apart the SK Snap rings seem the hardest to take off get back on.
I give up on my SK 1/4 drive just oiled it from bottom.
R
rjvjeepster
Luckily, I found it! Didn't expect that.
And yeah, these things are a massive pain...from now on I'll probably just do an ATF soak every now and then.
plinker
Northern Wi
I usually try to put the ratchet in a vise so you dont have to try and hold it and put it back together at the same time.
I thought the Craftsman RHFT style were trickier due to the spinner wheel, especially the 1/4 drive..
R
rjvjeepster
What kind of pliers do you use? I might pick up some 90deg needle nose ones. I got it once before with regular needle noses.
dutchgray
Dorset. England.
They are a pain to do as you usually have to fiddle with the drive end while on it with the pliers to get it to drop together I find. Hold in a vise, use a plastic bag over the head as a catcher if it goes ping.
JohnDeere1
Kentucky
I've had them snap, just had a craftsman Rhft San ring break I had to cut up an So one and bend it to fit its bigger.
They are a pain to remove especially with age and crud it took me an hour to get an Sk Wayne apart.
The BEST pliers to use are the 90° snap right pliers for me but angled needle nose are okay but try the snap ring pliers my snap on one's have a bend to the tips that hold them great they've worked for all the straight ones work also.
