SnapOn socket chroming...
CoThG
Are SnapOn sockets chromed after they are broached or before? I've watched some videos where it's claimed that Tekton sockets are not chromed on the inside. That would make them susceptible to corrosion.
Boogerman
aspen cove hill
Several years ago, this covered several threads, you might search "SK sockets painted inside". Got to the point where guys were trying to warranty their socket sets because they weren't chromed inside, and they were hoping the replacements were.
Gist of it is; sockets not chromed inside, or chromed to less extent. Many just dipped in silver paint.
Just use them, don't worry about it. Unless you just tool collector; in that case, wax the inside and it will keep unsightly rust stains away.
Here's some thread links from my quick search:
tamaraw
I believe for all chrome plated tools, this is done as the last step after forging/broaching/stamping/polishing. Otherwise the chrome would crack/peel from the other processes.
Sockets not being chromed on the inside or not to the same extent or not polished is extremely common and will not affect the durability of the tool on its own.
Jacobs976
Indiana
Chrome isn't going to be maintained inside the socket over time anyhow. Every time it's used it's an act of mild abrasion, which is why sockets wear out over time too or anything else metal on metal, so just oil them occasionally and rust won't be an issue.
Garcky
Twin Cities Metro Area, Minnesota
Who cares if the inside of a socket is chrome plated? I don't get it.
It reminds me of a sales pitch I saw at a state fair booth for some "miracle" knife or another. The pitchman, somewhere in the pitch said, very quickly, "Never needs sharpening - never take it out of the box." All in the flat, uninflected tone that pitchmen use so nobody will listen to it.
All of those sockets you never use will stay shiny and bright for decades, too.
Ricky Joe
Roanoke, Va.
If anything, it will add to the durability of the socket. Chrome takes up space, and when it chips or wears, the socket may no longer fit well. I prefer unchromed sockets and wrenches for that reason.
purplezr2
Central MN
Guessing these are plated on the inside, but it more of a satin finish, no high polished like the outside.
finn
The UP, God's country
Chrome is the last step, except for possibly polishing.
Chroming the inside of a socket is a sign of bad in house process. Chrome will develop micro cracks in use, and those micro cracks eventually migrate into the base metal and can cause a catastrophic failure.
Back when chrome plating was common on piston rings, the vendors developed a high crack content chrome plating to alleviate this. Lots of tiny micro racks wouldn’t propagate, so ring breakage was reduced.
Some fuel injection parts, like wave washers, have a high crack content chrome for the same reason. Low crack chrome eventually develops large cracks, which propagate into the base, then the washer breaks.
Sockets don’t really go through a lot of cycles in their lifetime, on a comparative scale, but, in any event, they do see relatively large compressive and tensile loads, and I wouldn’t be surprised if the same crack generation and propagation scenario exists. I suspect this failure mode is one reason impact sockets are never chromed.
Given a choice, I would stay away from sockets that are internally chromed, all other things being equal.
Steve_P
Insides typically aren't highly plated because nickel and chrome usually doesn't "throw" well into recesses; especially on large depths and small diameters; like a one inch diameter hole thru a 6" thick part. You tend to get a mess; some call it *************.
It also changes dimensions as said. And it's just not necessary.
Draftpick1
Not a socket but Snap On chrome related I have a new Snap On wrench that has some sort of factory defect in either the forging or chrome brand new out of the box 3/4 reverse ratcheting wrench 1/4 long spot with some pitting
Walkers
Cave Creek Az
That is usually what they look like when dropped on a battery!
Hit it with a buffer, or live with it, or trade it back in. For the price of them today they should be damn near perfect!
Draftpick1
I sent a picture to Snap on, they sent me the wrenches directly waiting to see what they say about it.
AEAdam
SE PA
That’s a defect and it’s structural. You need a replacement wrench.
That doesn’t look chrome related. Looks like the underlying material is defective. If customer service gives you any ****, I’d ask to speak to engineering. No engineer will say that’s ok, or you can just ”buff it out”.
