Snow Blower Impeller Mod
Sumboodie
AK
I did the impeller mod to my Snapper 1030, and was underwhelmed. It never clogged before, still doesn’t. Looking at the impeller and surrounding housing, it’s already pretty close tolerance. I’m guessing that the ones reporting big results are on blowers with a lot of clearance between impeller and housing.
I welded 1/4" plates on the blower on my tractor to close up the clearance. The previous owner had a dirt yard, so it had chewed it up some.
GTO
NJ,FL
I find that as long as mine is adjusted , my two stage Ariens 28" works just fine without the impeller mod.
kelpaso1
MEMBER EMERITUS
New Brunswick
Yes you are correct. If you have a 1/2 clearance then the mod makes a BIG difference.
jonshonda
Wisconsin
The gap is probably there to make manufacturing easier and less expensive. A tighter gap means the impeller must be made to tighter tolerances. Impellers are usually a welded fabrication, so a little leeway in terms of that gap means a lot.
The gap is there cuz of dummies sticking fingers in there. You could easily make a fixture to make the tolerance tighter when welding.
Mr Ratchet
Just did mine a few weeks ago. Only used once since I did it and it works great. I clear a pretty good spot out back for the animals to have a place to eat when I put out feed. Mine gets sand, sod, stones, and sticks in it and has widened the gap over the last 20 years. I used 1 1/2" wide strips of aluminum against the rubber instead of washers. I also used stainless bolts, lock nuts, washers, and lock washers to keep everything in place.
Renegade1LI
long island ny
I was ready to replace mine till I found this impeller mod, night & day difference. I think if they came with a rubber impeller seal less people would stick there hands in there, it never clogs anymore.
Renegade1LI
long island ny
I saw someone do it once, it isn't pretty, he lost 3 fingers & the other 2 are like ornaments. It is amazing what people take for granted.
DGersic
DeKalb, IL
It's likely the difference between deglove and delimb.
Ive seen mine injest, shred, and spit out the remains of a Chicago Tribune back when kids delivered newspapers to driveways. I don’t think an arm would even slow it down much.
rlitman
Long Island
Mine's eaten newspapers, but a phonebook stalled it.
My worst, was a 24oz ball peen hammer. I picked up the hammer at a flea market in the fall and it was too nasty to take into the shop, so I left it outside by the door awaiting a re-handle-ing. Well, it got forgotten and was quickly buried by leaves. It made a terrible racket going through and left a good goose-egg bump on my steel chute going out (thank goodness I don't have a plastic chute). I found the head and splinters of the old handle in my lawn in the spring.
DGersic
DeKalb, IL
Does it make a difference on what side of the impeller blade the rubber goes on?
Do you think this mod to the impeller blade would make would work (make a difference) on a pull behind leave rake?
The blades on my impeller are L shaped. The mod has to go on the inside, leading side of the blade.
If your impeller has straight blades, maybe either side would work.
No idea what the mechanism on a leaf rake looks like.
Y00PER
Keweenaw Peninsula, MI
Precisely why I keep moving South. Your photos give me PTSD of living in the U.P. eight years...
Some of us are smart enough to move south, others like me must like bitching about winter for 8 months of the year and added debt of trying to get bigger and better stuff to move the 300" of snow every winter
kelpaso1
MEMBER EMERITUS
New Brunswick
Put them on the "top or leading edge" of the blades. Mine had a good 1/2 of clearance between the blades and housing and after the mod it shoots the snow 2-3 times as far. If your impeller blades are bent up at the ends there is no need to put the rubber on the bent part, just the straight part of the blade. To secure the rubber "paddles" I just drilled 4 holes through the rubber and impeller blades and used 4 self tapping tech screws. No need for a metal plate on top of the rubber paddles.
BTW large truck or semi mud flaps make good flaps since they have some kind of cording reinforcing molded into them instead of just plain rubber.
thool
Rochester, NY
I have been tempted a number of time but have NOT made the mod yet. I really don't need to throw the snow any further, and where I am located we don't get enough slush to make this a needed upgrade.
However, I did service the valves according to the mechanic's shop manual, and the power increase is very noticeable. To me, being able to get through heavy snow without bogging down had higher priority.
greg13
Weedsport, NY
I think the FWD speeds are ok. I've tried adjusting it in the past, I can try again. But that wont help it through heavy snow.
That blower has an actual transmission in it, not a a friction disc like other blowers. The machine is well worth rebuilding. They were a top shelf machine and would easily run over $1000 new today.
Firebrick43
West central Indiana
I'm considering it, but......
My old Gravely 2 wheeler without flaps. With flaps, I might have more than just the closest neighbors complain.
With the older dog eaters/ma115 blowers flaps really helped. With the snow cannons like you have not so much.
When you want to blow your snow on your neighbors drive, buy a gravely snow cannon!
csp
Franktown, CO
With the rubber on the leading edge the snow on the impeller will put pressure on the rubber where it's attached to the blade vs trying to pull it away if it's on the trailing edge.
PoorUB
Fargo, ND
A Toro Powershift? Even a smaller HP unit would be way over $1,000 today. I don't know for certain, but I bet that 624 Powershift was a $1,000 when they quit building them in ~2004.
I have a 1028 Powershift. It retailed for $2400 in 2004, or about $3500 today. It is a monster, a heavey beast and it likes a lot of snow and is a pain in the backside to run, but when the snow is deep I have not seen another blower of it's size that does any better. I have one of those little Toro 5HP plastic pladdle machines for the light snow.
As for the blower mod, I did one on mine a couple years ago, it made a bit of difference in heavy snow, but it made a major difference in light snow, and slush.
As for the gap, manufacturing and room for debris, rocks and what not.
bsaint
Manchester, CT
The phrase of the day in this thread is "night and day" lol.
I also did the "mod" to a mtd. The improvement was **like night and day** It really uses all the power of the motor. My little 5hp cleared snow better than my dads 8hp or whatever it was.
PoorUB
Fargo, ND
Wrong. The less the gap the farther the snow gets blown and less chance for a rock getting jammed in the impeller.
No argument on a tighter gap blowing snow farther, I don't know why you brought it up! I never said otherwise.
As far as the tighter gap the less chance a rock getting jammed, I disagree with that completely.
kelpaso1
MEMBER EMERITUS
New Brunswick
Err, ok believe what you want. I've been fixing blowers for over 20 years and know what I'm talking about.
PoorUB
Fargo, ND
You are not the only small engine mechanic here!
I ran a shop for years too!
If there is a 1/2" gap, 1/2" rocks and smaller pass right on through. It doene't even notice 1/4" rocks. If the gap is tighter than 1/2", 1/2" rocks can get jammed in the impeller.
Fatboy148
I have a 7' Lucknow unit on the back of my tractor. I had two real nice long handled aluminum shovels that had heads like a coal shovel with nonstick finish that I used to shovel snow. I lost one maybe 20 years ago when I forgot that I had stuck it in a snowbank. It didn't slow the blower much at all, but it did make a little extra noise as it went through.
scooby074
Nova Scotia
Clearance is a bit of an issue for me. My tractor blower usually lives outside. If I did an impeller mod to it Id be worried that any ice buildup in the fan area would jam the fan. As it is right now, any rain/freezing rain/ water runs past the blades and drains out a 1/2" diameter hole drilled in the fan housing. Closing up those gaps could allow water to stick around and freeze instead of draining.
Clearance for rocks is a thing too. I suppose it depends on the gravel on your driveway.
bsaint
Manchester, CT
I agree with you too. I think the gap is to 1) keep debris from grinding in between the blade and housing and 2) to keep things from jamming on there. They must figure anything smaller the engine can over come.
chipjumper
Central Wisconsin
Gap between metal-to-metal is good for the rock jam issue but the rubber wipers can have minimal gap. I haven’t had a issue and I have a gravel driveway.
kelpaso1
MEMBER EMERITUS
New Brunswick
Exactly! I would get rock jams all the time without the rubber wipers. After I did the mod not one single one after that.
mark-NJ
new jersey
Does anyone have any pictures they can post? I have an older 5/24 MTD...all these years later, it still starts on the very first pull! Great machine, still in great shape, and I treat it to new belts, friction wheel, etc. regularly. But mushy snow does clog the chute, so this thread intrigues me!
Pics would be great, if you can post some. I think I "get it", but some up-close pics would sure help...
Thanks!
