...so I bought this house.
stokefire7
Mostly repair so far. Testing the drainage.
Second pic is a non ABS filler break. The others were all on the hall bath lav, three failures: screw penetration, void in the joint and cracked pipe. After repairing the screw hole, retesting , repairing the void, retesting and finding the crack, I ended up tearing it out and replacing it all.
More than likely a stinky bathroom.
stokefire7
I'm about ready for the basement bathroom.
ARFLY
NW Arkansas
That is a lot of work you have going there, and looks like a lot more to go. Are you living in it now?
stokefire7
I'll have it under test today or tomorrow.
stokefire7
Inspection tomorrow.
This is 5 lbs. at 30 mins.
Lelandwelds
Central Texas
I have owned two houses.
One was built in 1948, 1952, and 1970. Single bathroom. It had four kinds of water pipe, three kinds of drain pipe, and three kinds of electrical. It had a spot with negative roof pitch. It had one inch of loose fiberglass insulation in the attic. Period. The floors, walls, door knobs, faucets, and everything was either obsolete or non standard ( custom, if you are feeling charitable )
But it had a nice lot in the perfect, perfect location.
Second house is triple the size for one third the occupants. Everything works and is a class leading choice functionally . (Nothing fancy or opulent. )
It is in the perfect, perfect location (for us at this life stage).
I wouldn't do anything differently if I could. I sincerely hope you feel the same.
stokefire7
This one has a great view .
stokefire7
Waiting for the gas co.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Is this to code....water around electrical that is so close?
stokefire7
Days over.
stokefire7
Earlier this fall.
stokefire7
100 psi. on this. Needs to be regulated.
stokefire7
Had to modify my Flexible Flyer.
stokefire7
Lotsa holes to patch in this one.
stokefire7
I scored at my local freight salvage place. 30' of 1" M, 10' of 1 1/4", various fittings and a valve . $50.00. :thumbup:
stokefire7
Found this a couple years ago on Ebay. Finally get to use it . 1/2 through 2, had to pull a couple to test it out. I love it.
  • 1 1:4%22 .jpg
    1 1:4%22 .jpg
  • 3:4 %22 .jpg
    3:4 %22 .jpg
Firebrick43
West central Indiana
I bought some tee extractors a couple of months ago. I am missing the inch pliers however. Looks like your missing the included drill. You are brazing/silver soldering(really brazing) the joints right?
stokefire7
Yes, brazing.
stokefire7
I put up the boiler to see how it's going to sit. I think it's gonna work.
stokefire7
Lady Luck smiled at me .
stokefire7
some progress
stokefire7
Almost ready for the floor.
thammel
Maryland
If you don't like the brick you could cover it with fabricated stone.... Would look really cool, I think!
Tom
Hilltopmasonry
Tom
Doesn’t have to be fabricated stone. There are plenty of manufactures of thin real stone as well which in my opinion looks a lot nicer
Here is one I did last year that totally transformed the boring fire place into a show piece
stm317
I'd whitewash it and throw a nice wooden mantle across it.
Kind of like this
wasfast
San Diego CA
Plenty of choices (skim coat, paint, tile, cultured stone, just clean it, etc.) but it more depends on what overall style you want. Are you going to use it as a conventional fireplace or perhaps consider a gas insert so you get more functional use out of it.
MissileBear
Western NY
Previous owner of my house painted over the brick and mantle w/ oil based gloss paint. Wish I could go back in time and stop him/her from doing it. I much prefer the brick, and there is no going back now....tried removing it manually and with chemicals, but the brick is the highly figured brick with a lot of holes/defects and the paint just wouldn't come out.
We opted to keep the old wood burning fireplace instead of going with an insert and I'm glad we did. We use it daily during the winter.
Maybe I'm just old fashioned.
stokefire7
Not good.
