Socket Drive Adapters: Which sizes/types?
oldschoolcraft
Bay Area, California
I don’t currently own any socket drive adapters. An old craftsman set I had came with 3/8 and 1/4 drive sockets but only a single 3/8 ratchet and a 3/8 square female to 1/4 square male adapter.
Part of me feels like I need one of every adapter to have a complete tool set. Every combination that might exist. Stepping up or down between 1/4, 3/8, and 1/2 but I know that’s stupid.
So what adapters do you guys use and what application are they used for?
When should they never be used? I assume putting a 1/2 to 1/4 adapter on my 24” 1/2-drive breaker bar would shear off a bolt.
That would be silly.
You need to stack a 1/2 to 3/8 and a 3/8 to 1/4 on the 1/2” sliding Tee.
And used it to break loose a hex Allen bolt that didn’t want to go. Didn’t shear the bolt, the hex, or the 1/4” anvil.
Was just more comfortable than using the 3/8” driver. Not often, but I use them all, where needed.
Black300zx
Elkton, Md
My view is that adaptors are cheap and I always seem to lose them, so I mostly take the quantity over quality route so that I've got a cheap set in every tool bag. Half the time that I use an adaptor it's in a appropriate situation where I don't need to worry about breaking a bolt, socket, or adaptor. The other 50% of the time, I'm using the adaptor because I lost a socket and just just need to get a job done, even if it means crossing my fingers that a 1/2 to 1/4 adaptor and socket hold together for that one bolt I need to torque (or loosen).
O
oldschoolcraft
For reference here’s the drive adapters proto makes. I find them to be a great high end value brand for the money.
Model #InputOutput
J52533/81/2
J52541/23/8
J52553/81/4
J52561/43/8
J54533/41/2
J56531/23/4
J58533/41
J585413/4
From this table, if money is no concern, which ones do you buy? The space they take up is relatively small.
Looks like you can step up or down one drive size. They don’t offer two steps in a single adapter.
Arizona
The adapters I seem to use the most are 1/2F to 3/8M and 3/8F to 1/2M impact adapters.
I used to use my 1/2F to 3/4M impact adapter a lot, but then I guess I ended up with the right sockets because I don't use it much anymore.
how about just a 1/2 to 1/4 adapter? Seems like using the second 3/8 intermediary adapter would cause reduction in torque and greater chance of something to break due to one extra piece.
Don’t have one, never seen one, don’t know if they even exist, don’t really care for the few times I would ever use it.
I had enough torque that I wasn’t worried about losses.
When spinning an 8mm hex drive, torque is not one of my concerns, the bolt is more likely to break than any component in my drive system.
Reality wins out over theoretical discussions, or any perceived OCD concerns.
ItsNemo
Canada
I have the full set of adapters from every size up/down one size where applicable in chrome and impact. About the only ones I ever use (and very rarely I might add) is the 3/8" to 1/2" ones in both directions. Only really use them where I'm missing the socket size or a bit socket or something in the matching drive size for the impact.
cgrutt
Recently bought an ICON 3/4 breaker bar for a project I was working on. Bought the ICON adapter set as well that included 3/4 to 1/2 so I could use some of my other sockets with the Breaker bar. Adapter set wasn't expensive IIRC want to say about $20 and it included 3/8 to 1/2 and 1/2 to 3/4 in both directions.
CoogarXR
I have so many dang ratchets and sockets, I rarely use adapters as "adapters". I usually use them as mini extensions if I need an extra inch of reach lol. You know, use the same socket size, but go down to the next drive size plus the adapter. The combination is shorter than a deep socket, but taller than a shallow.
O
oldschoolcraft
Intermediate-length socket makers hate this one simple trick!
Benny Franklin
I got a couple sets of impact rated adapters from HF, and I use them all the time.
1/2" female to 3/8" male, 1/2" female to 3/4" male, and 3/4" female to 1" male are my most used
cvairwerks
Within hearing distance of Texas Motor Speedway
Two each of both directions for every step.... 1/4 -> 3/8, 3/8 -> 1/4 and so on. There are times you might have to go up and down on a single stackup. Additionally, with having both directions, they can be used as very short extensions when working tight spaces.
Samuel D
I don’t have tools above 1/2″-drive but have every single-step permutation of adaptor for 1/4″-, 3/8″-, and 1/2″-drive.
It’s a motley collection of brands that I picked up as I ran into the need. The adaptor usually doesn’t match the socket or wrench handle brand, but that doesn’t bother me.
My main use for them is to be able to use the best torque wrench for the job. I have a few torque wrenches in different drive sizes, but none of them are the modern electronic ones with a huge torque range at high accuracy. So it’s useful to be able to choose the ideal torque wrench for the torque rather than the drive size of the socket I want to use.
cgrutt
I just used an adapter the other day for just that reason. My 1/2 torque wrench was too long under vehicle so used adapter and my shorter 3/8 torque wrench which just barely fit...
cgrutt
So curiosity got the better of me had to see what adapters I had in my box I really don't use them all that often. The top ones in plastic are ICONs (HF) which I bought a few weeks ago. 3/8->1/2, 1/2->3/8, 1/2->3/4, 3/4->1/2. Bottom row have been with me a long time and are a mix, which I probably acquired with other bulk purchases along the way and decided to hold onto. Unbranded 1/4-> 3/8, Walden 3/8->1/2, Master Mechanic 1/2->3/8 and an SK and Snap-on 1/2 -> 3/4
Xcursion88
Uppers and lowers..
SK # 4506
Made in USA!
Marvin Berry
Northern NY
I'm pretty set for 1/4, 3/8, and 1/2 sets, so, obviously, the best ones to have are the ones I don't: a 1/2 > 3/4 adapter, so I can use even bigger sockets with my 1/2" ratchet; and a 3/4 > 1/2 adapter, so I can buy a giant 3/4" breaker bar to use with my 1/2" sockets.
dscheidt
Outside of the few times when i've had to use a **** set of borrowed tools (which always seem to come iwth a 3/8->1/4 drive for small sizes), this is about the only thing I use them for. I finally got a complete set of metric hex sockets in 1/4 drive, so I no longer need to use them when working on bikes, which was the last place I was using them with any frequency.
Hannahranga
For the step up adaptors the "Reducing Sleeve Adapter" style ones like a Grey Pneumatic 1138RA are imho worth it. Especially if you're using a torque wrench and don't want the extra length. As to which ones in generally you'll inevitable end up with all of them but I'd want to make sure you've got atleast 3/8 to 1/2 and 1/2 to 3/8.
AEAdam
SE PA
What’s the downside?
Caveat: For automotive
2 different scenarios, adapting up eg 1/4” ratchet to 3/8” socket, and adapting down, eg 1/2” ratchet to 3/8” socket.
Adapting up allows you to drive a socket sized for a fastener that requires a torque that exceeds the driving tool you are using. Not sure why anyone would do this when midget ratchets and every length of extension are available in every drive size.
Adapting down offers the opportunity to use a drive tool larger (really heavier) than required for a socket/bolt of that size.
In both cases, the advantage seems to be to have more options for what ratchet, extension you use for any given fastener.
In reality, the addition of the adapter takes up value space, adds another joint in your drive line, and offers the opportunity to break something. I own, but never use an impact step down. Maybe not dangerous, but certainly more risky since you don’t really get great torque feedback from an impact….takes experience to sense what they are doing.
The solution is to procure ratchets and extensions in a range of sizes for each drive size. My advice is to island hop the std length models and choose instead the ends of the range. Start with long flex heads, and stubbies. (Don’t need 1/4” drive stubby). That mid length ratchet should be chosen for low ratchet angle (fine tooth count) and low back drag, not necessarily highest strength. Ditto the stubby. (I personally find nearly no use for std length 1/2” ratchets. I go from my flex stubby, to my 26” flex head. I have a worn out F80 that I love.)
I have all dual80s. Fantastic in the long handled versions, but unnecessary in the shorter lengths. Other ratchets may be better optimized for lower back drag, sacrificing some max torque strength, which you don’t need/won’t use if you have better, longer options.
Adapters exist principally because, in the old days, ratchet gears/pawls were the weak point in the drive line. Ratchet manufacturers didn’t generally make long ratchets because folks could pretty easily shear teeth. We used breaker bars. And to get the handle where we wanted it, some of us used 12 pt sockets. A step down adapter allowed you to increase the effective length of a ratchet that once upon a time didn’t exist. Adapters gave us the opportunity to drive a 3/8” socket with a longer 1/2” drive ratchet. Ditto, stubbies weren’t popular and strong ratchets meant low tooth counts and high back drag, which really limited the functionality of the ratchet. So step ups gave us lower back drag, lighter, faster ratchets.
Today, the gears/pawls are stronger than the square drive, so most all modern ratchets are as strong as breaker bars, which has rendered breakers obsolete. Pawls engaging multiple ratchet gear teeth have allowed fine teeth to be used, which has substantially improved back drag with no loss in strength.
F-22
Feels so reassuring to use a 3/4" ratchet to untighten lug nuts, but I usually use a 3/4" to 1/2" adapter for the 17mm lug nuts.
ecotec
I have all the adapters up to 1/2” to 3/4” and 3/4” to 1/2”.
I rarely use them, except for a 3/8” to 1/2” one that I use for pipe plugs in conduit bodies.
My take is like a broken record… unless you have an immediate need… buy them on the secondary market for a fraction of the price of new. They are not an everyday tool, and there is tonnage of lightly used made in USA adapters out there.
I do not want to pull them out of my extension drawer… but they are in there…
dukefx
They do exist, but they are extremely rare. Popping a 1/2" socket onto a 1/4" ratchet seems to make a lot more sense to manufacturers as it's far more common than the opposite, but still an uncommon adapter. Personally I'd never use a 1/2" socket on a 1/4" ratchet but could imagine using a 1/4" socket on my 1/2" sliding handle and extensions (I have plenty of those) for hard to reach places.
ThePostman
Virginia
I've shared off many lower end adapters in the past. My 3/8 to 1/4 chrome is a Matco that has held up well. I also have a 1/2 to 3/8 impact that is Matco as well that's a solid one piece build, it's strong, but I'm not a huge fan of the hog ring and o-ring at the end. The Mac and Snap-On two piece 1/2 to 3/8 I also own have yet to break. 3/4 to 1/2 I have a taiwanese Williams solid piece that hasn't broken yet, and the newest acquisition is a Mac 2 piece that has a little bit of a lower profile than the Williams, it was able to break free a crusty axle bolt on a q5, so far so good with that. Ideally, you don't want to have to use them, but sometimes there's no choice. I'm not going to buy a 3/4" 19mm hex socket for one time or rare use, considering the 1/2 drive snappy is just about as bulky as something in 3/4 would be.
Madjik Man
Over the past 30 years it seems like I collected every combination of step up and step down within the 1/4, 3/8 and 1/2 drives.
Do I use them all? No.
Would I buy every single one in one purchase? No.
But I like having them for sure. And they were bought over a 30 year period so the amortization is palatable for me.
PelicanPines
I have adapters that fit the ratches and breaker bars I want to use. They adapt to the sockets I also want to use. As far as which ones... the simple GJ answer is ... all of them that you will ever need given the sizes needing "adapting"... I don't have any 1 inch adapters... I don't have a 1 inch ratchet or 1 inch sockets. You get the point. You wouldn't go from a 1/2" ratchet or breaker bar to 1/4" sockets either. The thought of that need or application is not logical. Stay logical. Stay smart...
Here is food for thought:
Just because you can "adapt something" from one size to another doesn't mean you should.
threewood
Yuma, AZ
I have one adaptor, 1/2" to 3/4" impact specifically for an upper ball joint socket that is only made in 3/4" drive. Definitely cheaper than 3/4" ratchets.
dchawk81
I have a 1" to 1/2" drive adapter. Throw a 1/2 to 1/4 on that and I can use my 5.5mm socket with my 1" d handle air gun.
AEAdam
SE PA
What could you possibly be doing that requires a 1” gun driving a 5.5mm? Is this a “I could in theory” or “I do”. No judgement btw.
I get it that these are tools and we love tools. This seems one of the most skippable tools
KnurledNut
n/a
DIY 1/2 to 1/4 adaptor:
Some time back, I took an old 1/2-drive 3/8” hex bit socket, removed the bit, and installed a 1/4”-drive x 3/8 hex wrench adaptor.
garfunkle24
Saskatoon, Canada
Yeah, don’t do it. Don’t use adapters.
Wow, what a useful answer and pretty much inarguable given the reasoning provided. I guess every single mechanic I know is just an idiot since they all have and use them.
OP: You didn't mention 3/4" so just get everything up and down between 1/4" and 1/2"
I sometimes stack adapters when I need a VERY specific length extension. I'm looking at you Subaru plugs on the left bank.
cvairwerks
There are occasions where I’ll go from 1/4 to 1/2 due to space limitations and it being easier to run fasteners in and out with one of my small 1/4 drive ratchets. Still break them loose or torque with the 1/2, but very limited swing space for the bigger stuff.
Meursault74
Southern California
1 7/16" socket 3/4 drive, 3/4 to 1/2, 1/2 to 3/8, 3/8 to 1/4 to micro 1/4 in ratchet. Just because I can. Just for this thread. :LOL:
