Socket suggestions
Bjkearns
Today I was doing motor mounts on my car and overall they went smoothly.
Snap On 17mm flex socket,24" extension and a FLF80 was my setup.
I used some door sealant gunk inside the socket to install the nut on the top.
It worked but that stuff was AWFUL to get out of the socket :shocking:
What would you guys use to hold a nut or bolt in a situation like that?
str8axle55
Ma
A piece of paper. Normal white paper will do. You put a small piece over the socket opening and force the nut in, works like a charm.
Haveblue
kansas
^^^ YEP! I usually use paper, or a gum wrapper to hold them in. tape is great too, especially for spark plugs
G_P
Central CT
I have even used leaves off the ground to hold nuts in sockets. It doesn't take much to keep it in there.
joedodge
Tampa, fl
Grease,paper,tape,paper towel, use them all depends on what's near me or what im doing grease works fine and wipes off fine.
greasemonkey44
memphis
usually magenetic sockets
but other times, grease, rtv, bits of rags
i used grease the other day on a 350 distributor cap to hold the torx screws
Oldndirty
north jersey
I use masking tape for nuts and 1/4 inch round rare earth magnets from harbour freight on the drive end of ratchet or extension for bolts.
ilovevocs
Toledo, Ohio
I wrap electrical tape around the top of the socket and let the tape hang over a bit when I wrap it. Pull it tight as you wrap and it closes off the end of the socket just enough.
