2mJps
I use both. If it is a crimp i will fill it with silicone before pushing the wire in.
I solder and shrink wrap. After doing what seems like everyones car stereo around here. they always ask why it takes a while longer than Best buy. I tell them because I solder and shrink wrap and they get it. Never had an issue with the installs.
Correct terminals & crimp tools aka T&B/Sta-Kon w/rare exceptions.
Which ones?I crimp only using nice Waytek ratcheting crimpers and the proper crimping jaws for the proper connector. Heat-shrink where necessary if I'm not using something like a sealed Weatherpack or Metripack connector.
Since I got a proper crimper, I prefer using it. However bad crimpers really make bad joints. I rarely solder any more.
Please explain.
Yes, a good crimper is essential. I got a pair of the SO PWCS7 Cutter/Stripper/Crimper a while ago and they are hands down my favorite. I literally use them things every single day. sometimes for the entire day, depending on the job.
if the cable/wire is a decent gauge then I print out connection details on a dymo label printer, tack it on and then use clear heat shrink to protect it
I'll solder if necessary, but prefer crimping because I'm **** at soldering![]()
Whoa, dont put silicone sealer anywhere near electrical connectors the acids in the sealant will wick down the wire and corrode it.
Both of those are traits of some guys I work with. Ex Telepower by any chance?![]()
Acid flux in electrical connections is a definite No-No.Right kind vs. wrong kind of solder?
Acid in plumber's solder corrodes the wire?
But there are multiple types of flux suited to electrical connections (rosin, water soluble, and no-clean). Stay away from the water soluble stuff, as that needs to be cleaned, and if it's not done thoroughly, is worst than not cleaning it at all (is active in the presence of water). Personally, I prefer using rosin, particularly for tinning wire (no need to clean it off).
Then there's the solder itself. Lead-tin alloys (60/40 or 63/37) would be the better stuff to use (doesn't have tin whisker issues like the lead-free stuff does, isn't as brittle, easier to tell if you have a good joint <nice and shiny>, and it has a lower melting point).
Anything automotive (or in my boat) gets crimped and heat shrink tubing. The flux and/or rosin used with the solder is very corrosive. The heat weakens the integrity of plastic insulation. And the soldered joint is prone to breaking via vibration because it is brittle.
Indoors with certain audio components and circuit repairs, I'll solder.
Take a look at the following:Rosin/Resin flux DOES need to be cleaned off. As above its outside the PH range for neutral (from memory its PH acid, I think??). Regardless it will cause issues if left in situ at process completion.
Unless you go to a specialty supplier the only solder available off the shelf is 60/40 (well at least thats the case here, might be different stateside) and usually it comes flux cored (usually Rosin/Resin) and most people who think they can solder actually cant tell the difference between a good joint and a dry one. If you have whiskering problems, you have WAAAYYYYY too much heat in the joint and have overcooked the solder.
Source. (direct to .pdf)Cleaning:
Kester 44 ... [snip]... In all these billions of solder
joints, involving the most delicate and critical of electrical and electronic components, there has never been
an authentic instance of corrosion by the flux residue under normal conditions of use. This mild property of
the residue permits leaving the flux on the assembly for many applications.
I'm sure he meant silicone grease.
I almost always crimp, but some occasions call for solder. Does any one else use marrets to hold wires together while troubleshooting? I end up doing that for trailers and such where some one has used all sorts of different coloured wires and you just need to hold them together to make sure everything works then remove marrets and wire correctly and neatly.
