Solid Wood Edge Corner Detail
shrttrackr
Frankfort, IL
I’m preparing to trim my work tops with solid oak trim. Since this is out in the garage, I’m looking for advice on the corner detail - should I miter the corner or **** joint them since they will be used quit e a bit. One of the corners is next to a lowered work surface for working on transmissions. IMG_4917.JPG
Shiftless
East Bay SFO
Yep, **** joints and radius the corner.
Plus, I would round over the top edge. That makes it safer as well as less likely to splinter or tear off if something heavy gets dragged up and over. Using a router and a round over bit is the best, but sanding works too.
BMW Rider
Calgary, Alberta, Canada
I'd do a **** joint too. Overlap the front over the side pieces as the front will see the most abuse. You could run a couple screws into the joint and cover them with wood plugs for added strength.
shrttrackr
Frankfort, IL
Great idea with the plug as one of the corners was somewhat warped and has a small gap at the bottom.
shawhite
What is the profile of the solid oak trim you are using? Is it just going to be a piece of 1x? If so I would just but it. Dovetail would look good and be a lot stronger **** definitely a lot more work but do able with a trim router and dovetail jig.
mike93lx
Richmond, VA
The dovetail comment was 100% a joke since the right answer (**** joint) had been given multiple times already
gte718p
Yep. And simple, and quick.
And boring and lacking finesse.
Go big or go home.
