Something just clicked…..
Strouty
Southern Maine
When I bought the unit, I looked it over fairly extensively, but I must have missed some loose bolts on one of the u-joint caps. It broke bolts off in the yoke, then broke the cap itself. Luckily it did not bend or damage the yoke on the rear end, of course I still have to remove the broken off bolts, so damage may be on the horizon. The u-joint was $125, it was a rockwell 6C that is similar to an old time mechanics joint. I guess they are common in industrial applications like this one. I am not sure if turning the forklift would have done this one in, but it does articulate, so it could be an issue. I do not tend to turn the wheel to the extreme limits as I know it stresses the axle joints, they are closed knuckle and don't look like they would be fun to repair.
dlcwent
Member Emeritus
coastal maine
From what you are saying and what I remember(which isn't much) those closed knuckles are a PITA. Maybe because we don't have to deal with that (anti)technology anymore. It should be a great learning curve for you.
Richard Cranium
central Washington
I went out and played with my tractor out in my horse pasture. Boy howdy is it ever had to plow snow with out digging into the dirt. I have a front loader on the tractor, it is also 4 wheel drive.
Strouty
Southern Maine
Even with my plow lifted, I hit a patch of sand and dug a hole, so now it will end up doing this all winter. I hope things warm up a bit more, I may get the excavator back over and try to level it back up. Problem is that area is all sand and it doesn't stay level unless it is totally frozen.
kaymccampbell
Upstate New York
Not to interrupt, but if you set your skids down 1/2" your plow will float over your sand and gravel. I do this for my once gravel and now crusher run driveway and depend on the Dingo's track marks for traction when it gets icy.
Strouty
Southern Maine
I don't use the any, I don't even have any. The biggest issue with the sandy area is it has not frozen and it is still uneven. The truck goes down over a hump and the blade digs and that is the end of it for the winter. Next year I plan on replacing the top 12" of sand with gravel, then it should be fine.
kaymccampbell
Upstate New York
If you want to level the humps from the excavator, and fix your new gouge, you could use the pickup to back blade it with the snow plow set straight across. I used mine to grade the mess left over after the professionals left.
kaymccampbell
Upstate New York
I will admit that I made my own from scrap, but modeled it loosely after an available product. Probably a Meyer.
And, saying that, on this commercially available plow there was a piece of tube making a vertical hole on each end of the plow. And that tube held a vertical rod with a saucer or ski like skid on the bottom. There may have even been a spring involved. It could be shimmed with washers to adjust plow height.
Strouty
Southern Maine
I have always removed them from every plow (mostly fishers), always just raise the blade a bit, but it usually stays cold and you have a nice snow path after that. It was back into the upper 30s after the snow, so it is not going to be as nice. I am not sure I have ever used them on any plow, I understand what they are for, but I don't care for them. I like the blade to hit the ground, especially when back dragging. I have also never plowed anything that was paved, not sure if they make things better for that or not?
legenddc
Agreed. Now there's nothing for me to read.
In the spirit of things, over the break I built a storage shelf so we can clean up some other areas of our house. We're starting to purge stuff now in preparation for a spring yard sale. It disgusts me how much stuff we've let accumulate that we need to get rid of. Certainly spent a lot of money on what's now junk.
Thumper68
Duluth MN
That is where I think they are best used. On gravel or dirt, they don't do much because of the humps and crowns.
I built some for the guy who plows our road a few years back, he uses a JD tractor with a plow.
What he needed and I built was more like a ski, about 12" long and 6 wide, piece of "C" channel with the post about a third of the way back and 2/3rds behind the post, that way they would stay straight and not twist around.
Gave him the support to float the plow and the length kept him from digging in. I believe he has them set so the plow rides about an inch high, anyway no more digging up the road every time he plows before freeze up.
I will see if I can do a design in sketch-up and post it.
There ya go, not exactly what I built but you can get the idea, only took a few scraps and little time.
Strouty
Southern Maine
Thanks guys, as noted before not much going on, I am a bit overwhelmed and because the shop is a 35 minute drive I don't feel like wasting an hour just to do something.
Of course today I did drive out and check things out. The snow is a little messed up, I wish I had plowed more, seems like the story of my life. I did get some bills paid and a quick bit of paperwork done. No I need to check my tires and fluids in the car before I head out. Tomorrow I may make more of a working appearance, I promise when I have some time I will update on the status of the inside. It looks a lot worse than it is, but I need some motivation to get over the hump. Thursday I am supposed to help my Brother for half a day doing a bit of tree work, so that should at least keep me occupied.
bimmer1980
York, PA
My Condolences. That ***** to loose a good companion. We've had to put down a couple over the last couple of years....
drivesitfar
Strouty: sorry for your loss. when my cat passed last May it might have been the first time i've cried in 50 years. you'll see your's some day hopefully way in the future because unfortunately pets are just here for small parts of our lives.
hope you and girlfriend just remember the good times with your furry friend and are thankful for the time you had.
Strouty
Southern Maine
We gave him 14 plus years. It was just an awful sight. He got a blood clot and it took out the back half of his body. He was howling from pain and being scared. It was a very sad morning.
drivesitfar
Strouty: mine had some infection that the Vets couldn't figure out so probably got it from a bird or another animal. after $1500 vet bill and surgery they wanted to put ours down for no charge. we took her home and she had 6 more happy years with only a few bad days, but the end was similar and she is resting peacefully now.
again it's hard and hope you are ok.
Thumper68
Duluth MN
Sorry for your loss, we came close to losing our dog this last week as well.
The surgery went well and she is recovering and hopefully the cancer was eradicated or benign.
LS6 Tommy
Northern NJ
I'm sorry about your loss, Strouty. We lost one of our cats last year. The Rainbow Bridge poem always chokes me up. I only hope it's true and we get to reunite with our non-human family members someday...
Tommy
Richard Cranium
central Washington
nasty looking over cast day here.
My brother in law called earlier and wanted to use my tire machine. I told him to wear his long johns, I have it stored in the barn for the winter. I keep it out side of the shop during the summer and then store it in the barn to keep it out of the weather.
