source for stainless braided hose for compressor?
Mattlt
MN
Why not just use a hydraulic hose? Less than $10 at any farm supply store.
robertlynk
California
This is the type I used on Industrial compressors MMC# 5680K15
High-Temp Type 321SS Braided Air & Water Hose W/SS Male X Male Fittings, 1" ID, 718 PSI
56145K65
High-Pressure Braided Fuel Oil Hose W/Stl Male X Male Fittings, 1" ID, 369 PSI
54FordPanel
Fort 54, Littleton, Co
I got mine at Home Depot. It's a hot water heater hose.
I'm sure somebody will tell me the 300 psi it's rated for isn't for air........whatever.
ddawg16
S. California
Yep....it's intended for water. Expect it to fail real soon......say 50-60 years give or take a decade or two.....
Gets my vote for quickest and most simple solution.
akdiesel
Wasilla, AK
Does it have to be brass ends?
I have gotten some Swagelok flex hose off of Ebay. More than enough pressure rating, but if you want to finish the system you have been working on then go for it.
moopa
Nanaimo, BC
Quoted from 54FordPanel "I got mine at Home Depot. It's a hot water heater hose. "
I used the same thing...very happy, and no problems with leaking,or rupturing...then again,the moisture coming out is hot(hence, its designed useage,water heater hose!)
Mark
ket-tek
My local Napa makes custom hydro hoses and has stainless lines and a full selection of -an, jic, or npt fittings also. I had a 3/4" x 22" one made up a couple years back for about $14 that I've been using as the output of a 4500psi tank with no issues..
akdiesel
Wasilla, AK
kettek are you sure you flex hose is rated for that pressure?
Plus it looks like you have a JIC fitting on the tank end. 1/2" JIC is rated for about 3500 psi.
Art From De Leon
De Leon, Texas
I had mine made up by McMaster Carr. I also got the Teflon lining.
The only thing I would have changed is to get 3/4" male ends instead of the 1" NPT male ends, but I had a friend get a couple of complete sets of 1" hammer unions out of the warehouse to solve the problem.
The hammer unions are rated at 15K working pressure, which is kind of overkill.
Torque1st
MEMBER EMERITUS
KC Metro, Kansas
Your water heater hose solution is just fine. -It is not PVC.
:lol_hitti
The only possible problem would be oil resistance. Time will tell. No worries about explosions. If it fails in 10-50 years just replace it.
Joe69
Muncie, Indiana
If all else fails, go to a semi truck dealer. They use braided hoses on the air-brake compressor. It's designed to take the heat and pressure. They come premade in assorted lengths.
Joe
fatboy99
Indiana
Joe
The Volvo truck dealer i worked at had the hose in bulk and end's thad had a taperd ferral. Very easy to assemble. That's what i used at my old garage havnt got around to plumb up the current shop only been in it for 8 years now:(
V
Vinko
Los Angeles
Thanks for all the replies. Much appreciated.
I don't live on a farm.
That looks about right, thanks.
I didn't notice that McMaster will make you up one to your spec. Good to know, thanks.
Overkill is alright :)
mrb
try hose-man or any other industrial hose supplier.
