Sourcing Air Compressor Piston Ring
carbureted iron
To others of the "repair before replace" mindset...
My stalwart, decades-old Craftsman 919167240 air compressor will not build pressure above 90psi. Disassembly and investigation reveals a slightly worn piston ring, while the piston head and cylinder sleeve are immaculate.
I cannot find a part number for the piston ring, and so I cannot a compatible replacement. The thing is 30mm ID, 47.5mm OD, 4mm lip, and fits within a 48mm bore cylinder sleeve. If you've replaced in the past this component in your aged but otherwise reliable air compressor, please post a link to the source you used.
Please see my comments here.
tak1313
Don't know if it will help, but a few years ago, I got an out of date CH compressor that needed new rings, but could only find it complete with piston.
For your model, would this help?
Edit - it appears others posted part numbers as I was typing my response.
dnschmidt
Phoenix, AZ
As a member of the replace and screw the repair crowd you want to spend money on an ancient air compressor that is louder than a jet engine and pretty much was a POS when it was brand new. Wait for the normal twice a month air compressor sale at Harbor Freight and buy a compressor that's one tenth the noise and puts out twice the air: https://www.harborfreight.com/27-ga...e-vertical-shopauto-air-compressor-56403.html
