spare capacity planning in trench
inphx
Phoenix/Scottsdale AZ
It seems like I am going to need to trench and pull power and water for 280 feet to my new residence and an additional 80’ to my toy shop.
Beyond whatever I need to do to plan – I am wanting to take advantage of the trench to put some conduit for power/internet (security devices) and future options in the hole while trenches are opened up.
A few questions for you guys/gals on two points:
1) what do you regret running
2) What to use for one or two conduits?
- 2 ½” pvc conduit? One or two spares
- What goes inside for a pull line– harborfreight nylon rope or a special pull cable(s)?
The shaded areas are "no fly zones" cant disturb or alter without mucho paperwork.
Sureshot
Bridge Creek, OK
I ran a couple water lines, air lines, and telephone.
The air is awesome to have and at my next place I will do the same. I have it plumbed right into the house on top of the cord reel in the garage. I didn't run it to the barn but sure wish I had.
Speedy Petey
NY State
For that distance two 2" would be more than enough.
I would not go to 2-1/2". There is a dramatic increase in price and some things will not accept 2-1/2" where they will 2".
I
inphx
thx so the 2" electrical pvc conduit seems way to go.
If i leave one as spare is there a special cord or just nylon rope?
sparky36000
North Dakota
We use stuff like the poly pull string like Petey is showing, but a small nylon rope is fine.
What size service are you going to have? Also, phone and cable companies don't like to share conduit so if you're planning on having both, then I would bury a 1" conduit for each!
mayday0017
Houston Texas
Curious but if the pipe was empty couldn't he put a sponge with some light weight string tied to it in the pipe later and go to the other end with a decent shop vac and pull it through? I"m just thinking fishing it through as you assemble would be a fairly slow and annoying process that could possibly be avoided.
Speedy Petey
NY State
I totally agree.
The two 2" I suggested were above and beyond the required.
In my area the phone and cable companies demand a dedicated conduit each.
For that kind of distance I'd go 1-1/2" for ph and catv, if not 2".
I use 1" up to about 100'.
Speedy Petey
NY State
That's the only way.
Fishing a string in as you go is caveman in today's world.
The string I linked is designed to be vac'd or blown in.
sparky36000
North Dakota
Guess I just assumed he was doing it after it was installed. Yes, vac it in after it's installed. A simple "mouse" made from a piece of light weight plastic and tied to to the bucket of poly line like Petey showed will shoot through like a rocket.
mayday0017
Houston Texas
YAY I did pay attention in Garage Journal class one of the other 100 times we have talked about running wires through pipe :)
Gary S
Bismarck, ND
I put 2 conduits in my trench. If I were doing it today, I'd put in a 3rd one for future use. I expect that some day I could use another one.
Forget pulling rope and string in a conduit. Do it like the pros do. Use an electrician's snake. It does 100x better job.
bygasper
Know what your electric codes require. I am required to run a 3" to the shop for a 400 amp service. I am then running 4 2" lines back to the house. Alarm, 3 switches in the house to turn on/off exterior lights at the shop, power...and whatever else I may ever want.
sparky36000
North Dakota
Been an electrician for 30 years and a vacuum with a mouse IS how the pros do it in long runs of pvc, way faster than a fishtape.
Gary S
Bismarck, ND
I never tried a vacuum. I tried ropes and string with poor success. My fish tape makes the job easy, so I haven't looked for anything else.
Jsf721
LI, NY
I would pull some line w/power for security cameras. Wrestling with this after the fact now in my own home.
I
inphx
Thanks for the great info, its a small expense for bigger and dual spares for the extra options it offers.
I think im a caveman cuz last time i did this i threaded wire as i added each segment.
Lots of valuable information in this forum. Thanks
CNGsaves
KS and OK
Curious about what depth you plan on putting each conduit??
Thus, is large 2 1/2" or 3" for electrical going the deepest (say 3 ft or more) and then smaller 2 conduit runs (ie maybe 2" or 1 1/2") for others (CATV/security/etc . . . plus Telco/Internet/etc) at maybe 2 ft depth??
For OP particular install, will there also be a separate trench for natural gas service?? That trench going to be dedicated to NG only, or you putting a spare conduit in that trench as well??
Aceman
Eastern Oregon
A walmart sack with a string tied on the handles will FLY down a 2" pipe using a plain old shop vac.
Norcal
Be sure to check PoCo requirements, here in PG&E territory they use EUSERC requirements & for a 100A or 200A UG service 3" conduit is required, they are not the only ones w/ a crazy requirement like that.
Speedy Petey
NY State
That's just idiotic!
Do you use special meter pans and panels with 3" KO's?
PatJ800
When I first moved in to my place I dug all my trenches all at once and put conduits and water lines to everywhere I was planning to build and everywhere I thought I might possibly build someday. I have several acres with a handful of outbuildings and several concrete pads with water hydrants for stock tanks and electrical for stock tank heaters. I used PVC conduit and black poly water line.
In the many many years since, I have never personally had any problems with my black poly, but the place I work has 34 locations and at many of the sites we have had problems with black poly buried in the past 10-40 years. It doesn't seem to matter if the poly is used for intermittent pressure for irrigation or constant pressure like a yard hydrant.
All the issues we have had at work have made me very paranoid about my black poly. With my luck I will start to have issues when I am just getting too old to swing a shovel anymore. If I could go back in time and do it over again I would use SCH 40 PVC.
VHF
NW Wisconsin
Once you figure out what you need, throw in one more empty smaller conduit (say 1") for future communications need (future CAT6, coax, or fiber.)
