Special inline spark tester needed
HanShotFirst
NW Nevada
Hey ya'll,
One of my motorcycles takes a spark plug without a terminal cap (the little screw on thing on the tip). So all the inline spark testers I find, won't fit that spark plug.
If that wasn't difficult enough...the plug drops almost 6" down the top of the engine, so I need something that's static (and in, not flexible) where I can press it down onto the spark plug.
Now, obviously I can do some work arounds to check spark, but I think my CDI unit is shot, so I really want to watch spark while cranking.
So anyone know of some type of inline spark tester that could work in this situation? If not, I'll just make one.
zendriver
Indiana
An inductive timing light would do it, but it wouldn't tell you the condition of the spark just whether there is one or not.
crf450x
Fall Branch, TN
Go buy a new plug for it from a parts store to keep as a spare. Should come with that screw on adapter. Then you can use whatever you want
LXCam
See if you can get a boot off a 04-05 5.7 hemi coil pack. That'll get you the 6" extension you're looking for and just use a cut bolt for the connection between it and a normal spark tester. The other side I'd do the same thing. Rig up a cut bolt to make the connections and tape it.
H
HanShotFirst
NW Nevada
I suspect that's how I'll end up doing things. Thanks.
Billythekid1
I just un screw the spark plug the hook the wire to the spark plug and lay the plug on something grounded the turn the bike over andwatchthespark plug u will see it plain as day if it's sparking good
