Spindle Sander Thoughts
calandrod
Kansas
I’ve been looking at this State Spindle Sander. I’m curious if anyone has experience with these and overall thoughts on them.
I have a spindle sander built into my cheap Asian drill press (Shop Fox W1668 with OSS). Its OK, but I don't do enough sanding to justify the floor space for a dedicated machine. If you are doing lots of curve sanding, template following, it may be more useful to you.
No idea about the State machine
shoot summ
That's a big heavy duty machine. Concerns are typically the spindles as sometimes they are hard to source, and table inserts. That one looks like it might have a leaking seal. Is it 3 phase or single?
jdepiero
NE, Ohio
Floor space would be a big issue for me also. I have the Harbor Freight one, and use it a lot. Seems to be holding up
C
calandrod
Kansas
I’m going to look at it Friday and figure out if it’s single or 3 but I can run either at my shop. Good point on the leaking seal.
marak
Anchorage, Alaska
That does seem a bit high, even by Alaskan standards. I am unfamiliar with the manufacturer, but have a great appreciation for older well-made equipment. Is there any issue sourcing sanding tubes? Having a mill and lathe can make it easier pulling the trigger on such a piece of equipment.
C
calandrod
Kansas
Ya I’m the same way. I love quality solid made old stuff. I have a lathe and a mill so I feel pretty confident I could make some replacement parts if I needed to.
Neighbor
As a patternmaker I have used that brand / type of spindle sander for many years. Very good machine. Useful but it's one of those unnecessary items. I have always wanted one. As others have mentioned verifying all the spindles, rubber sleaves and throatplates are there is important. I would want to verify 3 phase / single phase. At $1,000 I'd pass.
C
calandrod
Kansas
Would $500 or $600 be a fair price or is this something I should be able to find for a couple hundred?
Neighbor
I would say $500 or $600 would be fair. I compiled an average from OWWM ten machines asking price averaged $919. A couple of single phase higher. A couple were all complete with fresh restoration. Square table is also a bit more desirable. Good luck!
