Splicing Inside Sub-Panel?
dwall174
Southeast Michigan
Can you install a power distribution block like this inside of a sub-panel to split the power from a 40-amp breaker into 2-circuits?
Doug
mm08822
Why not use a quad breaker instead of adding this distribution block that doesn't belong in a small panel? Much cleaner, less space, probably less cost.
Is each circuit 40A ?
D
dwall174
Southeast Michigan
Because as far as I know they don't make a quad breaker for the QO series Square D sub-panel I installed a few years ago.
The QO series double pole breakers are rated for dual wire terminations, but only up to 30-amps.
Yeah, I have a 5hp. RPC that's wired to a 40-amp breaker & I would like to also run (not at the same time) a 5hp. VFD off that same circuit.
Doug
kaymccampbell
Upstate New York
I was in your predicament, and instead, ran from my single 240 breaker to an Eaton sub box with an Eaton BQC240240 40A Quad Circuit Breaker in it, so I could split my 240 line into my lathe and dust collector, in a small form factor. It looks a touch weird, but it works.
mike93lx
Richmond, VA
Doug
Finally, an application where homeline is better! :)
Thanks for the details. Blue wire nuts will do dual #6 and it would cost about 5 bucks
mike93lx
Richmond, VA
mm08822
Now with more details, I understand your predicament.
Before you go further, ask yourself, how many more ckts will my shop need in the future? Will I keep running into the same problem?
Is now the time to bite the bullet for a larger panel? Or hold off for now and just use a few blue wire nuts as a temp for the interim?
D
dwall174
Southeast Michigan
Just to aggravate me a little more, the cover actually has 4-more spaces in it. :headscrat
I've thought about that! :rolleyes:
However, I'm pretty much out of room for anymore equipment in the garage.
Doug
toplessHO
central florida
Whats the can made for?
if it lists one with a larger breaker count,gut the breakers,install the new
interior and add your breakers
mikedodge
Why don't you do like most people and stick a junction box outside the panel somewhere to branch off to the different loads?
Older (25+) used different tandems. If you can find single pole (120V) tandems, you can shuffle the single pole breakers around and fit another two pole breaker in.
D
dwall174
Southeast Michigan
If you're referring to the electrical box behind the cover?
The original panel is a 125-Amp panel with 12 spaces/12 circuits. QO112L125PG
The only panel I found with the same size box is a 100-Amp panel with 16 spaces/24 circuits. QO116M100P
Looking on the Schneider / Square D Website even though the boxes are the same size, the box numbers are different.
Swapping the guts may work, but it would probably involve modifying the mounting holes/slots.
Doug
toplessHO
central florida
Doug
Check on the guts swap if the box is same size the only difference may be the label.
There is a company thats doing panel upgrades and makes the guts and covers for
many obsolete panels. So its UL approved for them to swap guts and provide a new cover
with the old can. That saves a lot of time and expense. In this case you have the cover.
The guts most likely are all screws or slot on bottom screws up top.
I bet the bottom mount is same on yours vs the 16 circuit,just need to drill and tap a couple holes up higher.
dave*99
Coastal NJ
I think he's referring to placing two single -space tandem breakers next to each other & tying the center two together to basically make a quad setup.
The problem with that, is my panel isn't designed for tandem single breakers.
The problem with that is the two center breakers would feed a 240V circuit without common trip. No bueno.
They sell the setup you are referring to. But it’s not for 240 circuits.
How? He has only 2 single pole breakers in the already full box.
Unless my eyes are bad (and they are) there is an empty spot on the top right. Only 2 of the 3 single pole breakers are in use. One tandem would cover that.
I do know that some load centers restrict the number of tandems and their locations. Not sure if there is a restriction on the number of 2 pole breakers on that load center.
I also know just because Square D no longer manufacturers a tandem 2 pole, does NOT mean they are no longer available !
Are you sure about that ?
I was told the same thing by Square D, but I found out that there was a discontinued tandem, that was still available. 4 of those NOS tandems saved me from replacing the load center or adding a sub
D
dwall174
Southeast Michigan
Ok you talked me into it! :unsure:
I was able to find a box (no cover) with the 16-space guts! The box is the same width, but about 4" longer.
I bet the bottom mount is same on yours vs the 16 circuit, just need to drill and tap a couple holes up higher.
That's what I'm hoping on. :beer:
just ordered it today from ZORO! They usually ship pretty fast, so hopefully I get it next week.
Doug
youre looking at the wrong pic (the deadfront cover in #4). you need to look at the pic in #1. notice the ground wires go right over the spot where the deadfront has 2 twist out covers? theres no space there. no buss bars for another breaker.
D
dwall174
Southeast Michigan
D
dwall174
Southeast Michigan
Curious. What was the price vs a whole new box ?
I couldn't find a 16-space full box/cover anywhere! Zoro sells the boxes & covers separately, I paid $66.00 for the box & 16-space buss/guts.
If I wanted to replace the complete box I could have gotten a 24-space box with cover in a value package with a few breakers for $135 at Lowes.
Doug
